20 Most Recent
Nokia E66 Smartphone Questions & Answers
Offline Mode
menu>setting>profile>SELECT GENERAL OR SILENT as you wish
9/8/2019 3:35:32 PM •
Nokia E66...
Answered
on Sep 08, 2019
Mi forgot ma security code
If you have forgotten your security code, you will need the security master code to reset the code. For the security master code, pass me your IMEI number, which will be obtained by dialing *#06# on your phone.
4/16/2018 11:57:41 PM •
Nokia E66...
Answered
on Apr 16, 2018
Hello,today my E66 fell in
Hello there, usually when your mobile device falls in water the last thing you want to do is charge it. At least this should be the situation for about a week. This is so because even though the device might come on the insides are not completely dry and electricity mixing with water inside the mobile device is the last thing you want.
Although if after you are satisfied that the inside of the unit is dried you can try charging again and if it does not charge then your charging port is bad and would need to be replaced.
Hope this solution has been helpful?
12/24/2016 12:53:27 PM •
Nokia E66...
Answered
on Dec 24, 2016
E66 sim card not valid
Hi, Your Nokia E66 may have been locked to its Network, that's why it shows "SIM card not valid". In order to use other networks, you need to unlock your phone. You can unlock your phone using codes. Contact your service provider and get the code from them, or else get it from online sites. Try
Superunlockcodes.com , they provide codes at affordable price, with simple unlocking instructions.
4/22/2016 1:56:47 PM •
Nokia E66...
Answered
on Apr 22, 2016
E66 nokia reset lock code
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
1/30/2015 8:49:16 PM •
Nokia E66...
Answered
on Jan 30, 2015
HOW TO SOLVE NOKIA E66 LOCK CODE PROBLEM
All you have to do is the 3 button reset. By doing this, you would reset everything on the phone and it would seem like a brand new phone.
1. Switch off the phone.
2. Hold down the following three buttons:
Green (the call answer button), * button, and '3' button.
3. While
holding these buttons, hold the power button for a second to switch on
the phone.
4. Release when the phone shows the nokia hands logo or
shows other signs of life like the language selection screen.
Hope this was helpful? Please comment for more information and thank you for using FixYa.
11/6/2014 4:51:05 PM •
Nokia E66...
Answered
on Nov 06, 2014
Nokia e66 knows no sim
hello dear. nokia e66 sim card ok but memory card insert, memory ic change same problem, please help me...
9/6/2014 6:14:16 AM •
Nokia E66...
Answered
on Sep 06, 2014
