20 Most Recent
Stanton C314 Tabletop CD and Mp3 Player Questions & Answers
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
My stanton c324 after i put a dics in it reads
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Cue button sticks
If the button sticks in the down position mechanically, sometimes there is a build up of sticky substances on the sides of the button plunger. If you take a small cotton-tipped applicator and apply a small amount of rubbing alcohol to it and rub on the sides of the button with it in the up position, this will help and sometimes eliminate the problem. It might take more than one try.
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are. The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
A year ago I bought a Stanton C.324 and now I have
Dust and dirt could cause this by getting in the gear rack that moves the read head.
Make sure no one has smoked cigarettes around this as that is devastating to the optics in the unit.
An internal cleaning is probably in order and there are very fragile elements within the unit. I would recommend taking it to a shop specializing in CD repairs unless you are really capable.
I assume you have verified that the power is good to the unit.
Not reading cds
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
The cd player dosen't work
sounds like a fried circuit board .whats the make and model? when did this start happening? suddenly, or what?
press, add a comment, in upper right corner to reply
