20 Most Recent
Comdial 8024-S Impact 24-Line Phone Questions & Answers
When I try to get my voicemail by pressing VMAIL
The only way to fix it without your vendor getting envolved is to try to reboot your voicemail server/phone switch(depending on the model of your system it can be inside of your switch or separate computer).
Your voicemail is down right now
How do I change display name on a Comdial Impact phone.
The Small Office lite is the voicemail system are you trying to change the name on the voicemail or the telephone set. There should be a comdial cabinet hanging on a wall if you look on the right hand side of the cabinet there should be a sticker with a american flag on it this sticker will tell you model
Comdial edge 120 incoming call handling help
It seems like you're trying to configure a phone system or a specific phone to have incoming calls ring on multiple extensions simultaneously or forward to another extension if not answered. The exact steps can vary depending on the phone system or model you're using. If you provide more details about the phone system or model, I can offer more accurate instructions. In the absence of specific information, here's a general guide on how you might achieve this:
**For Most Phone Systems:**
1. **Ring All Extensions:**
- Log in to the phone system's administration interface.
- Locate the call forwarding or call distribution settings.
- Look for options related to "Hunt Group," "Ring Group," "Call Distribution," or similar terms.
- Create a group that includes the extensions you want the incoming calls to ring on.
- Assign the group a number or label.
- Configure incoming calls to be forwarded to the assigned group number or label.
2. **Forward After Rings/No Answer:**
- Within the same settings area, look for options related to "Call Forwarding" or "Follow Me."
- Configure the settings to forward calls to another extension or voicemail after a certain number of rings or if there's no answer.
**Example for Asterisk-based Systems (such as FreePBX):**
- Log in to the FreePBX administration interface.
- Create a Ring Group.
- Add the extensions you want to include in the group.
- Set the Ring Strategy to "Ringall" or "Ring All Available."
- Specify the Ring Time (how long it should ring on each extension).
- Save the settings.
- Create a Follow Me setting.
- Add the destination extension(s).
- Set the Ring Time (how many seconds it should ring).
- Configure the Follow Me List to go to the next destination if there's no answer.
Please note that terminology and options might differ based on your phone system's manufacturer and model. It's important to consult your phone system's documentation or seek help from your IT department or phone system administrator if you're not familiar with the settings or if you're dealing with a complex setup.
Keep in mind that making changes to a phone system's configuration can impact its functionality, so it's a good practice to do so during non-peak hours or with proper testing to ensure everything works as expected.
