20 Most Recent Timex T Series Perpetual Calendar #T2M458 Watch for Men Questions & Answers
The date is advance by
Hi isengard03,
Setting the day on your Timex analog watch is a simple process. Please follow the steps below.
Multi-Function Models
1. Pull the crown on the side of the watch case all the way out. This will be position "C," with position "A" having the crown pushed all the way in and position "B" being pulled out halfway.
2. Turn the crown clockwise until the correct day appears on the small face displaying the day.
3. Press the crown all the way in, to position "A."
Chronograph Models
1. Pull out the crown on the side of the case to position "B." This is halfway out. You will feel a slight click when the crown is in position "B."
2. Turn the crown clockwise until the watch face shows the correct day.
3. Push the crown all the way into position "A" to complete the process.
Hope it helps.
Thank you for using FixYa.
8/15/2011 12:54:19 PM • Timex T Series... • Answered on Aug 15, 2011
0answers
I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
6/29/2010 3:01:41 PM • Timex T Series... • Answered on Jun 29, 2010
Is there a manual for Timex women's T5K187?
https://www.google.com/search?q=Timex+women%27s+T5K187+manual It looks like you will have to contact Timex direct as the manufacturer doesn't list a manual for it although they do have other Ironman models. ..
3/9/2024 6:18:04 PM • Timex Watches • Answered on Mar 09, 2024
I left my timex solar watch in my watch case too long - and it stopped working. How do I repower the watch. (I have had it out in sunlight for a couple of days).
I am thinking you need a new battery. It appears to be a battery operated watch that runs on solar power IF there is light. How long will a Timex Solar watch last? The solar movement functionality creates an environmentally-friendly and maintenance free timepiece that can be charged through indoor fluorescent light or outdoor sunlight. Once fully charged, the battery life can reach two months. If worn daily, there is very little chance the watch will stop.
Solar Powered Watches ' Timex Blog
11/30/2023 7:43:05 AM • Timex Watches • Answered on Nov 30, 2023
Timex Expedition with Hydra Timer started randomly changing time and functions. Battery was replaced 1 year ago.
Either a loose connection inside or it just needs a new battery. They can be power hungry depending on how you use it and what battery technology type was used in the last one.
How Long Do Timex Watches Last? (Watch & Battery Life)
watchesoftoday.com https://watchesoftoday.com > Blog A Timex watch battery will last between two and five years, depending on how often you use the Indiglo feature, while the watch itself can easily last five to ...
8/26/2023 1:47:55 AM • Timex Watches • Answered on Aug 26, 2023
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly. Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
8/14/2023 8:57:55 AM • Timex Watches • Answered on Aug 14, 2023
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads timex.cahttps://www.timex.ca Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers. Rating for timex.ca: 3.7 - 209 reviews - Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex https://www.timex.ca > watch-manuals Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz https://manualzz.com > Fashion & style > Watches View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
7/10/2023 5:10:55 PM • Timex Watches • Answered on Jul 10, 2023
Timex T5K143 Ironman. How do I get a replacement band for the watch please?
Question edited for clarity.
Replacement Watch Bands & Straps
Timex https://www.timex.ca > browse > replacement-straps Replacement 18mm Resin Strap for Ironman® Essential 10 Full-Size. C$ 15.99. Strap Only StrapOnly. Replacement 20mm Bracelet for Highland Street Gray large.
  • Replacement 20mm Resin Strap for IRONMAN Classic 30 ...
    https://www.timex.ca > Replacement-20mm-Resin-Stra... Replacement 12mm Resin Strap for Ironman Essential 10 Mid-Size. C$15.99 ... I had to have a jeweler mill down some of the plastic so the band would fit. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3.1 · ‎8 reviews
Timex Ironman Watch Bands Replacement
Amazon.com https://www.amazon.com > timex-ironman-watch-ban... 5pcs Compatible with Timex Ironman Classic 30 Watch,Ironman Essential 10 Mid-Size Watch Replacement Silicone Band Holder Loops with a Tool to Remove The ...
Replacement Straps for TIMEX IRONMAN Watches
Timex https://www.timex.com > browse > ironman-replaceme... Replacement 15mm Silicone Strap for Ironman Essential 30 Gray large ... Replacement 18mm Resin Strap Watch for Ironman 100 Lap Modular Black large.
Total Watch Repair https://www.totalwatchrepair.com > collections > timex... Total Watch Repair sells Timex Ironman Watch Bands and Replacement Straps online. ... Timex Ironman Indiglo Triathlon Shock Black 18mm Rubber Watch Band.
Timex Resin Wristwatch Bands for sale
eBay https://www.ebay.ca > ... > Wristwatch Bands 44 Results ; 14mm Timex Ironman 30 Lap Navy Blue Ladies Replacement Watch Band TX754261T. C $20.28. C $48.76 shipping ; 15mm Timex Ironman Triathlon Blk/Orange ... ..
5/4/2023 3:06:06 AM • Timex Watches • Answered on May 04, 2023
I Don't know to set up of the TIMEX DIGITAL WR100M IRONMAN CLASSIC 100 THAT I JUST GOT/// HELP
A lot of watch manufacturers use the American style date layout of Month/Day/Year. Try this. Looking at the watch press and hold the bottom right SIDE button for 3 seconds. It should enter setting mode where the seconds display will flash. Press the Right FACE button once. It should switch to the Hour display flashing. Press the same button again to go to minutes and them again to go to the date display. Repeated pressing of the top Right SIDE button changes the numbers upwards, (1,2,3,4), and the Left FACE button changes the numbers downwards, (4,3,2,1). Press the Bottom right SIDE button once to finish and go back to the normal display. http://assets.timex.com/manual/W-9.pdf
3/23/2023 6:21:08 PM • Timex Watches • Answered on Mar 23, 2023
Has Timex come up with a solution for all the Expedition watches losing time?
We aren't Timex, we are Fixya. Contact them direct. Make sure you are using the right compound of battery, not just the right size. https://www.google.com/search?q=Timex+Expedition+watch+that+keeps+losing+time https://www.fixya.com/support/r27181038-changing_watch_batteries ..
3/9/2023 6:10:06 AM • Timex Watches • Answered on Mar 09, 2023
2answers
How to reset my timex 637 t5g951 wr 30 heart monitor
To reset your Timex 637 T5G951 WR 30 heart monitor, you can follow these steps:
  1. Press and hold the "Mode" button on the front of the watch for three seconds until the watch display shows "Settings."
  2. Press the "Next" button on the side of the watch to scroll through the settings menu until you reach "Reset."
  3. Press the "Mode" button to select "Reset." The display will show "Yes" and "No."
  4. Use the "Next" button to scroll to "Yes," and then press the "Mode" button to confirm.
  5. The watch will reset and return to the time display.
Note: Resetting your Timex 637 T5G951 WR 30 heart monitor will erase all your saved data and settings, so you will need to set it up again after the reset. If you need to keep your data, consider transferring it to another device before resetting the watch.
3/3/2023 5:47:16 AM • Timex Watches • Answered on Mar 03, 2023
3answers
Manual for a Timex T5K360 Ladies Marathon Watch
https://www.timex.com/watch-manuals.html I didn't see it there, but they usually provide contact information to request assistance. https://www.amazon.com/Marathon-Timex-T5K360-Digital-Mid-Size/dp/B00284C9SM Amazon vendors often answer customer questions on their web site. Examples: Question: does this watch count distance? Answer: No, this watch does not count distance. It has two time zone settings and a stop watch. By Mindyx on June 24, 2017 See more answers (4) Question: Does this watch show seconds as well? Answer: Yes. By Mom of three on July 22, 2017 Yes the seconds show on the face along with the time. By Pati D on July 21, 2017Collapse all answers Question: What is the length of the watch band - I need at least 8" in length Answer: 6 inch By PromenadeWatches SELLER on August 4, 2017 Tip to tip (including buckle) is 9 inches. 8 inches without the buckle By Brittney on August 1, 2017 Hello, standard wrist size for a women's watch fits a maximum of 7.5 inches. By Timex Customer Service MANUFACTURER on August 3, 2017 Collapse all answer Question: IS this a chrono watch? Answer: Hello, thank you for your question. Yes this watch has the chronograph feature. By Timex Customer Service MANUFACTURER on August 29, 2017 No, it is not a chrono watch, but it has a 24-hour stop watch. By Mindyx on August 28, 2017Collapse all answers Question: Does this watch have presets for the countdown timer? For example 30 secs, 1 min, 3 min, 5 min, 15 min, 30 min, 45 min, 1 hour? Thank you! Answer: No By Mom of three on February 16, 2018 Hello, thank you for your question! This watch doesn't have timer feature. By Timex Customer Service MANUFACTURER on February 20, 2018 Collapse all answers
Question: Does this watch have a countdown timer? Answer: Yes, this watch has a 24 hour countdown timer. By Timex Customer Service MANUFACTURER on March 13, 2017 No. But the size of the numbers and night light button are great features. Has count UP timer. By Mom of three on March 13, 2017 Collapse all answers Question: How do I change the time showing back to international (military) time? Answer: By pressing the lower left hand button to scroll through he screens, go to where it displays the time with the date up above. Press the upper left hand corner button once. By Mom of three on August 16, 2017 Hello, thank you for your message. Here are the instructions in setting the time including the time format. To set time and date: ... see more By Timex Customer Service MANUFACTURER on August 15, 2017Collapse all answers
3/1/2023 8:14:33 AM • Timex Watches • Answered on Mar 01, 2023
I have a timex expedition. Eventhough the battery is new, the alarm and the beep function does not work properly. I have to shake the watch to make it work
If your Timex Expedition watch alarm and beep function are not working properly, even with a new battery, it could be caused by a few different things. Here are some steps you can try to troubleshoot the issue:
  1. Check the alarm settings: Make sure the alarm is turned on and set to the correct time. Also, check that the alarm is set to the correct mode, such as daily or weekly.
  2. Check the watch's manual: Refer to the instruction manual that came with your watch to see if there are any specific instructions for setting the alarm or beep function.
  3. Check the vibration function: If the vibration function of the watch is not working, it could cause the alarm and beep to not function properly. Try resetting the watch or contacting Timex for assistance.
  4. Check for physical damage: Inspect the watch for any physical damage such as a cracked or broken case, or a damaged alarm switch.
  5. Check for water damage: If the watch has been exposed to water, it could cause damage to the electronic components. If water has entered the watch, it is best to take it to a professional watch repair center for service.
  6. Check if the watch have a warranty: If the watch is still under warranty, you should contact the manufacturer for service or repair.
1/27/2023 5:03:44 PM • Timex Watches • Answered on Jan 27, 2023
How do i turn off
To turn off the hourly chime, just press the MODE button (bottom left) until the watch is in alarm mode. Then press the ST/STP button (top right) and the icon for hourly chime should go away.
11/4/2022 3:15:05 AM • Timex Watches • Answered on Nov 04, 2022
My Timex ironman won't beep and the indiglo won't work.
IndiGlo uses a separate battery as the watch has two. Take it to a local jeweler and have both batteries replaced.
4/27/2022 1:14:56 AM • Timex Watches • Answered on Apr 27, 2022
How do l change the battery on a Timex Chronograph, battery type CR2016 ?
Undo the screw with a pro-grade jewellers screwdriver.... or ..... Tip & How-To about Watches Changing Watch Batteries Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10! Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15! Posted by ADMIN... on Dec 31, 2018
3/29/2022 4:49:28 PM • Timex Watches • Answered on Mar 29, 2022
How many batteries does a timex expedition railroad pocket watch have
One battery.
3/19/2022 3:17:18 AM • Timex Watches • Answered on Mar 19, 2022
Timex T Series Perpetual Calendar #T2M458 Watch for Men Logo
4 questions posted
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
date advance
  • Watches
