20 Most Recent
Timex T5G341 Sports Radio Control Watch Questions & Answers
Stop alarm
ask your watchmaker to remove/disengage the alarm spring
My screen has gone blank.
the problem of your watch is only the battery.. bring it to watch service center for replacement of battery. i'm happy to help you!
Cannot change from 24 hour to 12 hour
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Watch will not programe to England Time
If it is 1 hour out it could be on daylight saving time setting (DST).
If you haven't got any instructions you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Timex T5G341 sports universal
battery should always be original otherwise it will destroy your watch.dont try to put the battery yourself give it to an company autherised shop and allow them to put it
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads
timex.cahttps://www.timex.ca
Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers.
Rating for timex.ca: 3.7 - 209 reviews
- Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex
https://www.timex.ca > watch-manuals
Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz
https://manualzz.com > Fashion & style > Watches
View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
I Don't know to set up of the TIMEX DIGITAL WR100M IRONMAN CLASSIC 100 THAT I JUST GOT/// HELP
A lot of watch manufacturers use the American style date layout of Month/Day/Year. Try this. Looking at the watch press and hold the bottom right SIDE button for 3 seconds. It should enter setting mode where the seconds display will flash. Press the Right FACE button once. It should switch to the Hour display flashing. Press the same button again to go to minutes and them again to go to the date display.
Repeated pressing of the top Right SIDE button changes the numbers upwards, (1,2,3,4), and the Left FACE button changes the numbers downwards, (4,3,2,1). Press the Bottom right SIDE button once to finish and go back to the normal display.
http://assets.timex.com/manual/W-9.pdf
