20 Most Recent Microsoft Visual Basic 6.0 for PC Questions & Answers
C programming of inventory management for a local shop
Why do you program in c or visual basic if you can do the job with a database software access for example and if you want your problem to be solved you must provide more info
12/12/2023 5:52:10 AM • Microsoft Visual... • Answered on Dec 12, 2023
How to fix Error 1935 On Microsoft Visual C++ 2008. I did everything I know, and it didn't work.
Question edited for a lot more clarity. Question moved from Miscellaneous. "Error 1935" indicates that there is a problem with the Microsoft Visual C++ Redistributable package, which is required by MATLAB. The error typically means that the package failed to install properly.
Why do I get a Microsoft Visual C++ Redistributable error 1935 ...
MathWorks https://www.mathworks.com > matlabcentral > answers
Install Visual C++ 2008 fails: error 1935 (Win7 64bit)
Microsoft Community https://answers.microsoft.com > windows > forum > all Sep 10, 2011 - This error may occur when the Microsoft .NET Framework installation on the computer is damaged or is missing. Try the below step to reinstall ... Error 1935 while installing Visual C++ 2008 Sep 24, 2019 Cant install Microsoft Visual C++ 2008 Redistributable ... Dec 24, 2021 Windows 11 - Error 1935 while installing Visual C++ 2008 x64 ... Jan 22, 2023 error 1935 while installing Visual C++ 2008 Redistributabl Jul 13, 2014 More results from answers.microsoft.com ..
10/23/2023 7:05:55 PM • Microsoft Visual... • Answered on Oct 23, 2023
3answers
Visual basic code for atm machine
visual basic code of atm machine
12/21/2018 10:12:51 AM • Microsoft Visual... • Answered on Dec 21, 2018
How to download visual basic 6 portable??
click on the link below to download it!
http://www.mediafire.com/?8zukiyimjkt
11/26/2018 7:08:47 AM • Microsoft Visual... • Answered on Nov 26, 2018
I want to use my Active X Control in My
You might want to re-think the ActiveX Control. The state of hostility concerning web controls make what you're trying to do hard. The link you provided won't even display on my system. a PHP downloader is far easier to program combined with user authentication the security is a little better!
6/28/2017 12:21:45 PM • Microsoft Visual... • Answered on Jun 28, 2017
How to add current date to folder name- updates automatically
newPath = "C:\Year\" & year(Date) Call MkDir(newPath) newPath = "C:\Year\" & year(Date) & "\" & month(Date) Call MkDir(newPath)
6/3/2017 9:17:06 PM • Microsoft Visual... • Answered on Jun 03, 2017
Problems of Hotel 1.Hotel has 20single
And ?
5/9/2017 7:55:56 PM • Microsoft Visual... • Answered on May 09, 2017
2answers
Hw to link database using visual basic
use adobc <------try this
dim rs as new adobc.recordset
dim cn as new adobc.connection
private sub xn()
cn.cursorlocation = aduseclient
cn.open "CONNECTION STRING" <------
end sub
private sub form_load()
call xn
if rs.state=adstateopen then rs.close
rs.open "select * from TABLENAME" ,cn, adlockstatic, adlockreadonly
if rs.recordcount > 0 then
set datagrid1.datasource = rs
end sub
11/14/2016 7:38:14 AM • Microsoft Visual... • Answered on Nov 14, 2016
I want to open a jpg and doc file through command button in vb6
try to convert it to vb6 file and open it via vb6.... heres the link >>>> http://3d2f.com/tags/vb6/converter/registered/software/
10/9/2015 12:15:50 PM • Microsoft Visual... • Answered on Oct 09, 2015
How can i develop a program that scrolls text on a display board?
Auto Hot Key is a good software to use. You can do macros for everything that you can do on a computer.
11/4/2014 6:01:45 AM • Microsoft Visual... • Answered on Nov 04, 2014
What is the advantages of visual basic 6.0?
1) It's simple language. Things that may be difficult to program with other language can be done in Visual Basic very easily. 2) Because Visual Basic is so popular, There are many good resources (Books, Web sites, News groups and more) that can help you learn the language. You can find the answers to your programming problems much more easily than other programming languages. 3) You can find many tools (Sharewares and Freewares) on the internet that will Spare you some programming time. For example, if you want to ping a user over the internet in your program, Instead of writing the ping function yourself, you can download a control that does it, and use it in your program. Compare to other languages, Visual Basic have the widest variety of tools that you can download on the internet and use in your programs.
8/7/2014 5:39:30 AM • Microsoft Visual... • Answered on Aug 07, 2014
Write a computer program to change fahrenheit to centigrade
'Convert fahrenheit to centigrade dim cent as int cent = Val(Text1.Text) // Text1.text as your input cent = cent - 32 cent = cent * 0.5556 Text1.Text = cent // Converted and changed the same textbox
5/8/2014 3:15:55 AM • Microsoft Visual... • Answered on May 08, 2014
How to make a horoscope code to visual basic 6.0
Private Function Horoscope(pBirthDate As Date) As String Dim pMonth As Integer Dim pDay As Integer pMonth = Month(pBirthDate) pDay = Day(pBirthDate) If pMonth = 3 Then If pDay >= 21 Then 'And pDay <= 31 Then Horoscope = "Aries" Else Horoscope = "Pisces" End If ElseIf pMonth = 4 Then If pDay >= 20 Then 'And pDay <= 30 Then Horoscope = "Taurus" Else Horoscope = "Aries" End If ElseIf pMonth = 5 Then If pDay >= 21 Then 'And pDay <= 31 Then Horoscope = "Gemini" Else Horoscope = "Taurus" End If ElseIf pMonth = 6 Then If pDay >= 22 Then 'And pDay <= 30 Then Horoscope = "Cancer" Else Horoscope = "Gemini" End If ElseIf pMonth = 7 Then If pDay >= 23 Then 'And pDay <= 31 Then Horoscope = "Leo" Else Horoscope = "Cancer" End If ElseIf pMonth = 8 Then If pDay >= 23 Then 'And pDay <= 31 Then Horoscope = "Virgo" Else Horoscope = "Leo" End If ElseIf pMonth = 9 Then If pDay >= 23 Then 'And pDay <= 30 Then Horoscope = "Libra" Else Horoscope = "Virgo" End If ElseIf pMonth = 10 Then If pDay >= 23 Then 'And pDay <= 31 Then Horoscope = "Scorpio" Else Horoscope = "Libra" End If ElseIf pMonth = 11 Then If pDay >= 22 Then 'And pDay <= 30 Then Horoscope = "Sagittarius" Else Horoscope = "Libra" End If ElseIf pMonth = 12 Then If pDay >= 22 Then 'And pDay <= 31 Then Horoscope = "Capricorn" Else Horoscope = "Sagittarius" End If ElseIf pMonth = 1 Then If pDay >= 20 Then 'And pDay <= 31 Then Horoscope = "Aquarius" Else Horoscope = "Capricorn" End If Else 'If pMonth = 2 Then If pDay >= 19 Then 'And pDay <= 29 Then Horoscope = "Pisces" Else Horoscope = "Aquarius" End If End If End Function
5/8/2014 3:10:52 AM • Microsoft Visual... • Answered on May 08, 2014
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report. Printing a Data Report Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event. Choosing to Display a Print Dialog Box When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box. To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print. Note Printers must be installed on the computer in order to present a choice of printers. Printing Without a Dialog Box In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range. To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False Or, to specify a range of pages to print, use the code below: DataReport1.PrintReport False, rptRangeFromTo, 1, 2
5/8/2014 3:05:55 AM • Microsoft Visual... • Answered on May 08, 2014
Microsoft Visual Basic 6.0 for PC Logo
314 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
make horoscope code visual baisc 6 0
  • Computers & Internet
