20 Most Recent Singer 7258.CL - Stylist 7258 Questions & Answers
0answers
What is causing tension and needle position problems?
If the machine is new, it is probably still under warranty. Contact the manufacturer. ...
4/5/2016 2:39:03 AM • Singer 7258.CL -... • Answered on Apr 05, 2016
How do I replace my bobbin housing correctly
9/28/2014 12:23:15 AM • Singer 7258.CL -... • Answered on Sep 28, 2014
Can not lower the needle to pick up bobbin thread on my Singer Stylist 7358 machine
Where the bobin is at re check the exterior of the part that spins you may have a thread stuck and keeping it in place use a flash light then replace bobbin as you depress the power controller asist the wheel this should free up the bobbin area and should run
2/4/2014 12:43:03 AM • Singer 7258.CL -... • Answered on Feb 04, 2014
Circuit diagram for ESP2 singer steam press
I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful. The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights. The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use. If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
2/26/2023 5:08:30 AM • Singer Irons • Answered on Feb 26, 2023
My singer iron has no steam
cheaper to replace it .. than fix it you might try a descale
7/1/2016 9:01:07 AM • Singer Irons • Answered on Jul 01, 2016
0answers
Breville vcf011
this is due to the open nidlle in the iron so they sound
1/25/2014 6:53:27 AM • Singer Irons • Answered on Jan 25, 2014
0answers
Singer 7258.CL - Stylist 7258 Logo
12 questions posted
Top Singer Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Singer Iron Expert? Answer questions, earn points and help others
View Most Popular
Singer Irons
  • Singer Irons
Most Popular Question
fix new sewing machine suddenly tension
  • Irons
