20 Most Recent Panasonic DECT 6.0 Expandable Cordless Phone with Digital Answering System Questions & Answers
How to set up Panasonic Answering Machine
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
5/19/2015 1:27:17 AM • Panasonic DECT... • Answered on May 19, 2015
Retreive a message
It appears that your telephone service company's voice mail service is active and there is where the message is being left.
5/12/2014 6:34:25 PM • Panasonic DECT... • Answered on May 12, 2014
0answers
Program answer message
Follow the instructions on page 37 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG6511-MUL.PDF
3/21/2014 6:36:40 PM • Panasonic DECT... • Answered on Mar 21, 2014
0answers
Can not get the light on top of the phone from
dont need too?
10/6/2013 10:37:00 AM • Panasonic DECT... • Answered on Oct 06, 2013
0answers
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself. I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement. If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider. If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee. I hope this helps. Cindy Wells(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
1/29/2013 1:13:22 AM • Panasonic DECT... • Answered on Jan 29, 2013
Panasonic KX-TG6071S
HelloCheck its battery. There is a rechargable battery. If the battery may look like good, it may ahve sufficiant curretnt carrying capacity. If so, this type of fault occur. Repalce the battery. OK.
1/24/2013 6:38:42 PM • Panasonic DECT... • Answered on Jan 24, 2013
Message light on phones keeps blinking on detc6.0 even though messages have been erased
Apparently you have subscribed to a voicemail system offered by your telephone company, and your phone is notifying you of messages on that system. Please contact your telephone company for instructions and help on accessing this system.
1/13/2012 5:49:01 PM • Panasonic DECT... • Answered on Jan 13, 2012
Digital cordless phone Model# KX-TG6413 lightning
If you are lucky, it may just be a blown fuse. You can try disassembing the base unit and checking for an open fuse inside on the circuit board. Please remember to disconnect the power supply and the phone line before disassembly.
Otherwise the circuits in the base unit were probably fried in the resulting power surge and are likely beyond economical repair.
However, the old handset(s) are probably still good. So if you do get a new replacement base unit of the same model, then you can probably salvage the old handsets and just program them for use with the new base.
I hope that was helpful, good luck and take care.
Joe.
8/13/2011 1:40:59 AM • Panasonic DECT... • Answered on Aug 13, 2011
I would like to change
I had the same problem but couldn't figure it out either ..... UNTIL, I changed the date and time (which was very old, actually Sept/2007) to the current date, year, time, am/pm, etc.
After I changed the date, time, year, etc. my phone went back to its normal default of 3 or 4 rings & then the answering message plays.
Hope this helps!
4/1/2011 10:12:04 PM • Panasonic DECT... • Answered on Apr 01, 2011
Panasonic DECT 6.0 Expandable Cordless Phone with Digital Answering System Logo
45 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
program answer message
  • Lands Phones
