20 Most Recent Logitech QuickCam Pro 9000 Web Cam Questions & Answers
How to install on a MacIntosh computer
10/20/2019 2:19:00 PM • Logitech... • Answered on Oct 20, 2019
Recording problem video memory is too large
Resolution plays a part in the size of the video. Avi takes up a lot of space. Try any program that can save in mp4.
6/6/2017 10:44:35 AM • Logitech... • Answered on Jun 06, 2017
Video conference with 4 people split screen
I have looked into this for quite some time...what if you get a lot more features in another software...!!! ooVoo is the software and you can use 6 people video conference with recording facility. The problem is Windows Live messanger has some technical issues when it comes to multiple video conferencing...hence ooVoo is for you. Download from here..http://oovoo.com/ there's a free version and trial version giving you full access for 30 days...no credit card required. There are other softwares but they are cheap stuff...so I suggest you to go for this one.
5/15/2017 8:45:36 AM • Logitech... • Answered on May 15, 2017
ERROR CODE 0X80004005 WITH VISTA 64 BIT
Quick Cam 9000 Error code 0x80004005 I was able to get it to work both by itself and with other software on my (HP Media Center Win 7) by lowering the image quality to 640 x 480 VGA.
8/26/2015 12:25:45 PM • Logitech... • Answered on Aug 26, 2015
0answers
Zeiss download
Be the first to answer 8/7/2015 6:28:33 PM • Logitech... • Posted on Aug 07, 2015Be the first to answer
2answers
Bagaimana caranya menggunakan driver nya untuk
hi.
tidak perlukan driver jika dipasang pada win7, ianya akan auto install, anda cuma perlu memasang perisian kamera sahaja seperti cyberlink youcam untuk anda menonton gambar anda sendiri dan jika anda hendak menggunakan kamera tersebut secara on9 sahaja, cukuplah sekadar menggunakan ym atau skype atau selainnya kerana kamera hanya perlukan driver sahaja untuk berfungsi.
6/27/2014 6:21:07 AM • Logitech... • Answered on Jun 27, 2014
0answers
2answers
Which firewall service is in use ?
The ICS service can be enabled along with teh Port 9000.
start the Windows Firewall/Internet Connection Sharing (ICS) service at the command prompt by using the net start sharedaccess command, you see the following output:
C:\>net start sharedaccess
The Windows Firewall/Internet Connection Sharing (ICS) service is starting.
The Windows Firewall/Internet Connection Sharing (ICS) service could not be started.
A system error has occurred.
System error 16405 has occurred.
Hope this will help you....
Cheers!!!
Vivek
The system cannot find message text for message number 0x4015 in the message file for BASE.
1/18/2014 4:30:12 PM • Logitech... • Answered on Jan 18, 2014
3answers
Web cam freezes after a few or up to 30 minutes.
Try to uninstall the camera and install the lastest drivers and also try another usb port
1/18/2014 4:29:58 PM • Logitech... • Answered on Jan 18, 2014
2answers
I just bought a logitech webcam and I am taking to
Typical audio set up
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
1/18/2014 4:29:45 PM • Logitech... • Answered on Jan 18, 2014
2answers
I have a problem with image of skype
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
1/18/2014 4:29:32 PM • Logitech... • Answered on Jan 18, 2014
2answers
How do I set up program to call people.and do the
The easiest and cost-free solution is Skype. While it is not necessary to have a webcam, you will be able to see people who have a web cam and they can see you. You will also have the ability to have voice only conversations with friends who don't have a webcam.
The free download can be found at www.skype.com
1/18/2014 4:29:14 PM • Logitech... • Answered on Jan 18, 2014
2answers
Upgrated to Windows 7 and downloaded Pro9000 new
Yes, it sounds like you hit the nail on the head. Look for updated sound drivers for Win 7 at your computer manufacturer's website.
1/18/2014 4:29:02 PM • Logitech... • Answered on Jan 18, 2014
2answers
I can't hear the other person but they can hear
Send this to them so they can properly setup their Audio & Video in the messenger or Skype they are using.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
1/18/2014 4:28:50 PM • Logitech... • Answered on Jan 18, 2014
2answers
I was told to uninstall my Logitech QuickCam Pro
From here:
http://www.logitech.com/index.cfm/435/6333&cl=us,en?section=downloads&WT.ac=sc|downloads||dd
Select the OS, select 32-bit and follow the instructions.
1/18/2014 4:28:38 PM • Logitech... • Answered on Jan 18, 2014
Logitech QuickCam Pro 9000 Web Cam Logo
445 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
QuickCam Logitech
  • QuickCam Logitech
Most Popular Question
logitech carl zeiss tessar 2 0 3 7 2mp
  • Computers & Internet
