20 Most Recent
Sony Bravia L-Series KDL-32L5000 32-Inch 720p LCD HDTV, Blac Questions & Answers
The standby mode is not working tv will not go on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Picture failure on my sony bravia kdl 32l5000
First check it by connecting a DVD player or games console to it to see if the picture behaves with them feeding it. I will assume they also fail. When it fails try going up a channel and see what happens then. So If the backlight (which is a few simple flourescent tubes) also went off AND the sound went off I would say there is a fault in the power supply, inside the TV, but the sound stayed on so this is a very unusual fault. I think it may be switching to a mode of operation where the picture is deliberately suppressed. A factory reset should have cleared this so there is an electronic problem, for most TVs its not cost cost effective to repair any of the internals.
Tv jumping and like there is a shadow in the inner
Do you think you can do it right?
If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Bad power supply?
First of all, please ensure that the power outlet is ok. During such power surges, normally the power outlet gets affected. Try the TV on a different power outlet. The relay clicking on/off could be due to some components short in the primary supply.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site.
thus the net in flix.
what did you mean by hooked?\
do you have internet at home at all?
do other things in home work to the internet, like PC or cell phones.
what I can not under stand is (different room) this phase
implies some rooms do work (netflex)
and wifi gets weak if my move any TV farther from the home router
and will fail past 25 feet or more. wifi is super weak through walls
for sure brick, or 2 walls.
if home is small one wifi access point is all you need
if huge home more.
distance matter, TV to router.
no TV model # told. (tells me wifi spec)
if you said my TV works in room 1 but not room 2, wifi;.
it be super more easy to answer.. is this true?
if true , get a tech to upgrade your wifi.
or go wired, Ethernet.(a better home upgrade)
No sound some channels
HI
IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY
THANKS
M NASIR
