20 Most Recent
Acer TravelMate 4320 Notebook Questions & Answers
Acer 4320 won't power up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:Possible causes:1. AC adapter failure.2. Power jack failure.3. Motherboard failure.Possible troubleshooting steps and repair solutions:1. Test your
acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter. 2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
I do not know wether
If you have it would be under device manager. What version of windows are you running?
I erased the volume in
Hi
some acer models differ slightly from other acer model but all actions are similar
please try this
start
all programs
acer
acer erecovery management shoul be about 3 different options in here
1.restore sysem to factory defaults this will wipe the c drive and restore to when you ist purchased it
2. restore operation system and retain user data but this option will not remove persistent viruses/malware
3. reinstall drivers/applications
on the left click restore
contents
scroll down to find the audio driver
go over to the green icon
hit the install tab
and let windows do the rest for you
please let us know if this has helped you
so that we may be able to help others
many thanks
I have forgotten my users
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.
Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
I flashed bios and failed.
My
You were warned!
Updating an incorrect BIOS may cause harm to your system. We recomend
that you only do this after being instructed by one of our Customer Care
representatives. By using these updates you agree to accept the
possibility of product failure.
There is no ned to update ANY BIOS on ANY system unless the update fixes a specific problem you are having which will be outlined in the release notes.
I have no sound on my acer trvelmate 4320 intel
well this maybe because of not correctly installed drivers
thats why your sound isn't functioning ;)
try downloading this
ftp://ftp.work.acer-euro.com/notebook/travelmate_4320/vista/Drivers/Audio_Realtek_v6.0.1.5543_Vistax64x32_AZA1VF1W.zip< for vista
ftp://ftp.work.acer-euro.com/notebook/travelmate_4320/driver/Audio_Realtek_v5.10.0.5423_XP.zip
<for xp
After formatting of my PC, the WiFi and the
since you formatted your system you might need to download drivers for your computer devices to work.... go to control panel and device manager if any question marks or exclamation point are showind then you will need to getto your ACER's website and download every driver that your system requires. to make wireless and bluetooh work make sure that you download win7 drivers to be specific for your computer......... and devices to run propwerly on your computer thanks
Seems to be powering off battery when plugged in
This will happen if the battery is flat, or near so, try replacing battery, connect up the power adapter, and leave alone for say over night, this should charge the battery. If it doesn't then you have to check, both the charger, and the battery, and replacement is the only real way unfortunately.
Hang-up problem
Search Intel Proset on google, download it and it will do the connecting process of wifi on your laptop. as for your computer. Try, reformating it with windows XP. There are no problems with it. I use acer travelmate 4320 too. and at first it is slow but when i reformatted it, it's processing is so fast.
