20 Most Recent
Pentax K10D Digital Camera Questions & Answers
Memory card error
Try using a different SD memory card. You can also try formatting your memory card, BUT that will delete everything stored on your memory card.
Pentax K10D shake reduction switch broken
Repairing the camera is little bit tough for a end user but it can be repaired in any service center as it is a Pentax k10D I will recommend you to keep this camera because this days getting a Japan made camera is as tough as getting water in desert.
I Inserted new Battery,after five - ten minutes,
Go in setting option and select your battery type from there. After that restart you camera if you face the same problem then visit service center. THe power transfer IC may be not so powerfull , need to change.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Why does it take so long to show to the photo after I press the shutter button?
The picture displays after the file has finished saving - if the speed of your SD card is slow, it can take quite a while before the picture is displayed. It also takes a while (up to a minute or more) if the shutter speed is low and the picture is mostly black (taking nighttime moon shots for instance).
Try using a better quality (higher speed) SD card.
