I understand you have a Bosch dishwasher you've performed a diagnostic and found the "Rinse & Hold" light illuminated, correct ? Provided it is indeed the B/S/H/ "evolution" series SHE33 dishwashers, here is a list of the error messages.
If this image is too blurry to read or too small after I send it (it appears fine on my PC monitor, but not sure how it will look once sent) let me know. I could possible send you the service manual if you think that may help you, but you would need to provide an email address for me to attach and send it to. It is "pdf".
Of course there are many possible scenarios (heater, hi-limit, flow switch or even the control) so I'll need to clarify the model if not correct before moving forward.
is the child safety lock to the left or right? (its located in a recessed space where the main handle is) if its to the left then its locked and will need to use something like a matchstick inserted in the small hole next to the switch to deactivate it.
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
