20 Most Recent Kodak EasyShare M883 Digital Camera Questions & Answers
How do I clear the memory
Format the memory. See page 33 of the user guide: Owners Manual User Guide for Kodak EasyShare M883 Digital Camera
11/16/2014 9:29:56 PM • Kodak EasyShare... • Answered on Nov 16, 2014
Wont turn on
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera. Make sure the battery is inserted correct and the battery cover should be locked correct. If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
3/23/2014 9:36:24 PM • Kodak EasyShare... • Answered on Mar 23, 2014
Kodak M883 will not accept charge when plugged to computer and will not go on either when plugged to computer.
Not all computer USB ports put out enough current to charge batteries. If you're connected through a hub, try bypassing the hub and connecting directly to the computer. If you have another USB port available, try that. If you have a USB charger that plugs into a power outlet, try that.
2/15/2014 3:51:56 PM • Kodak EasyShare... • Answered on Feb 15, 2014
Lost cd
Do you really need the Kodak software? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
1/15/2014 7:01:42 PM • Kodak EasyShare... • Answered on Jan 15, 2014
0answers
Lost software cd
Contact Kodak service center.
7/13/2013 12:51:18 PM • Kodak EasyShare... • Answered on Jul 13, 2013
Need price for a new battery
8 USD with a charger from here.
2/23/2013 10:39:50 PM • Kodak EasyShare... • Answered on Feb 23, 2013
How to transfer images from eternal memory
Take a look at this page from the user's guide.
7/10/2012 4:13:15 PM • Kodak EasyShare... • Answered on Jul 10, 2012
When i try turn on my camera it makes a buzzing noise, as if its trying to turn on but the lens does not come out any solutions?
Check to see if the retractable dust covers on the lense, if one of or both are knock out of there track that they slide in.
3/1/2012 6:45:30 AM • Kodak EasyShare... • Answered on Mar 01, 2012
2answers
Turns on and zooms in and out then turns off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/6/2012 6:05:49 PM • Kodak EasyShare... • Answered on Feb 06, 2012
Should i lube / oil the zoom lens
Hi, Don't put anything on the lens mechanism. Take it to London Drugs to the camera section they can help you with this. Good luck.
12/25/2011 7:48:36 AM • Kodak EasyShare... • Answered on Dec 25, 2011
I have a Kodak Easyshare M883 and when I turn it
I have a possible answer to your problem but FIXYA will not let me send it to you.
10/11/2011 4:06:40 AM • Kodak EasyShare... • Answered on Oct 11, 2011
My memory card said it
Does the camera still recognize the card? Like can you see the picture stored in the card using the camera's LCD display? If you can then use the USB cable that came with the camera and connect it to your computer. This way the camera will show up as an external drive in your computer and you should be able to copy the pictures from the camera to your computer.
9/7/2011 9:12:09 PM • Kodak EasyShare... • Answered on Sep 07, 2011
My M883 is not working.
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
6/26/2011 12:30:03 AM • Kodak EasyShare... • Answered on Jun 26, 2011
I have an M883 Digital
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/30/2011 1:10:21 AM • Kodak EasyShare... • Answered on Apr 30, 2011
My Kodak easyshare m883 won't import my pictures
Try NOT connecting your camera to your computer.
4/25/2011 5:20:12 PM • Kodak EasyShare... • Answered on Apr 25, 2011
Kodak EasyShare M883 Digital Camera Logo
85 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
when try download
  • Cameras
