20 Most Recent
Lexmark X2550 All-In-One Printer Questions & Answers
Installed new 28 and 29
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Need to empty toner tray.
Below the Flat Bed Scanner Glass!!!! Just Pull it Up you would see the Cartridge Carrier there!!!!!
%Build Template Error Message% when trying to ininstall
I think this is an ongoing problem with Lexmark printers. After doing a bunch a digging with just the right phrases, I found this link on the Lexmark site.
ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
It ran a little strange, but eventually rebooted my computer. After coming back up, it was still finishing up in the background. I went back to check if the program was still there in the add/remove and it was. This time when I clicked on it, Windows told me that it had already been removed and asked if I wanted the Lexmark removed from the add/remove. I selected yes, did a manual reboot and everything is clean. Finally!!
I hope this helps anyone sharing the same headaches as I've been experiencing.
TM
The printer does not print
HI
THIS PROBLEM IS DUE TO POWERSUPPLY
PLEASE CHECK WHEATHER IT IS GETTING ON
AND CHECK WHEATHER DRUM IS WORKING OR NOT
AND CHECK FROM POWER SUPPLY TO THE PRINTER BOARD CONNECTED OR NOT
X2550 ink problem, i just had it run out of black
Try to manually wipe the black cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the black cartridge. If error continues, please contact Lexmark technical support for additional assistance.
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
NOT PRINTING FROM USB
if you use a laptop.
please assure the port on setting properties (driver) it must be the same with your plug on laptop.
see a picture
