20 Most Recent American Standard Trane Ge Gas Furnace Flame Sensor Sensing Sen00355 Pse-tr9 Questions & Answers
Furnace manual
What is the problem? If its not sensing the flame? Try rubbing off the build up of the carbon on the sensor off with a piece of emery cloth or some sand paper. If it works after you clean it. Replace the flame sensor. It should work for you for a little while after the carbon build up is cleaned off. Not sure of what exactly the problem is. But with a flame sensor the only thing it does is confirm there is a flame to keep the gas flowing thru the gas valve. Its one of the many safety features on most if not all gas furnaces. If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
4/2/2014 4:00:34 AM • American... • Answered on Apr 02, 2014
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
10/31/2013 10:26:28 AM • American... • Answered on Oct 31, 2013
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
1/26/2013 7:33:47 PM • American... • Answered on Jan 26, 2013
Furnace fan will not run manually or otherwise
Check motor winding resistance (line to line and line to body). If this is okay, check if the wires are cut or disconnected to the terminals. If wires and connections are okay, replace the capacitor.
11/13/2012 3:08:30 AM • American... • Answered on Nov 13, 2012
3answers
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fa
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
3/18/2023 2:27:59 PM • American... • Answered on Mar 18, 2023
What happened when you connect red white and green?
I don't know, I don't have a red, white and green! :>D This seems to be an American Standard package unit? https://www.google.com/search?q=American+Standard+package+unit All question need full 'make model (what it is)' as the first three words and then a clear concise question of what the problem is and what you might have tried.
11/18/2022 3:05:24 AM • American... • Answered on Nov 18, 2022
American Standard HVAC unit: white Rodgers control board, code calling for heat. Nothing starting induction fan
There is a sensor in the furnace that tests to be sure the vent pipe that takes the exhaust out is clear, I had a furnace a few yrs ago where that sensor failed and it wouldn't light, it could call for heat but nothing would happen
11/28/2021 1:46:24 PM • American... • Answered on Nov 28, 2021
I have an American Standard unit showing error 91
Had error code 91 on Trane XL19i thermostat. Heat season on duel fuel system. Repair tech said board is bad ($963) and transducer ($1000). Unit is 3 ton 12 years old. Does it make sense to repair or put in a new unit?
2/21/2020 12:54:27 AM • American... • Answered on Feb 21, 2020
American standard communicating air handler and heat pump blower wont come on new board 4 months ago any way to check the variable speed blower motor
High and low voltage AT the motor with no motor function is a bad motor. Should have 12 to 13 volts DC on r+ and r- (I believe are the correct terminals) You must test this when the machine is trying to run. Yes, it's dangerous, hire a licensed contractor!!
6/21/2019 11:00:20 PM • American... • Answered on Jun 21, 2019
2answers
American standard 80 only lights on second cycle, any known reason?
check pressure switch
5/23/2019 6:25:22 PM • American... • Answered on May 23, 2019
Awakened to find my American standard unit was displaying an error code of 79, wt to do
low pressure fault, you need service
5/18/2019 11:40:22 PM • American... • Answered on May 18, 2019
What does error code 79 mean
low pressure cut out. refrigerant leak
3/26/2019 2:45:53 PM • American... • Answered on Mar 26, 2019
I have American Standard error code of 156. What do I do to correct?
american standard error of 156... on a car? If PO0156, thats an ODB2 sensor... possibly the second O2 sensor on your emission system. You can reset the code and see if within 100 miles it lights back up... Likely it will. You may have a burned out catalytic converter... or a bad O2 sensor... or a blown head gasket, or many other things. If that is the ONLY code I would go forward with the O2 sensor. Look it up on ebay, year, make and model of car. Typically if one o2 goes, the other will follow. It is symptomatic of the cat going out though. How many miles on the car? More than 150,000? Likely its the catalytic converter. They are a consumable in your car. It will affect your mileage significantly while the code is on, and typically if it is the o2 sensor itself that has gone bad ( between 30 and 100$ per) and the cat is ok, if you don't fix the o2 sensor, the cat will burn up (cost between 200 and 700, and a bunch to swap out) Get it checked out, you're looking at more bucks the longer you wait
2/24/2019 6:07:06 AM • American... • Answered on Feb 24, 2019
How to reset my American standard thermostat it's defaulting to a 40 degree setting.
are you running a schedule? try the permanent hold!!
2/15/2019 5:02:16 PM • American... • Answered on Feb 15, 2019
Adaptive intelligent recovery: how to disable the feature in American Standard ACONT800
Google tcont800 installation manual. option530 should be 0 not 1. Press system button, 2 and 4 square hold until screen changes, option 530 --0
1/17/2019 2:04:29 AM • American... • Answered on Jan 17, 2019
American Standard Trane Ge Gas Furnace Flame Sensor Sensing Sen00355 Pse-tr9 Logo
Popular Tags
8 questions posted
Top American Standard Heating & Cooling Experts
Steve Sweetleaf
Steve Sweetleaf
Paul Carew
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Heating & Cooling
Most Popular Question
furnace fan will not run manually or
  • Heating & Cooling
