20 Most Recent
Coby MPC895 MP3 Player Questions & Answers
Converting itunes videos to amv files for my kids
I have been using this program with real good results. It will convert any video into a mp4 which is what you need.
http://www.any-video-converter.com/products/for_video_free/
Copy this address into a new window.
File System Error?!
I have the 4GB version (non-FM) and it's having the same issues. I reformatted mine to the NTFS filing system in hopes of uploading my songs faster since these players run on FAT32, but reformatting it to any file system other than FAT32 will cause it to give a File System Err notice on your player. I would suggest reformatting it to FAT32 using your computer. There are resources available everywhere online that shows you how to do this.
Will not come up on the windows media player
You will need to go to coby website, download the latest drivers. Once downloaded, doubl-click on the file so installs itself. Once completely installed, the restart your computer and then it will connect.
Help plz
depedns on if it rechargable or not look at the back take it off to see if two sprimngy things are there or and hard battery if so then you can recage it with an ubs cord if and spring then batteri (like rechargeable engerzier)
Coby mp3 893
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Coby mpc7097 el playlist solo llega a 200 temas
lo que puedes hacer es formatearlo desde mi equipo "my computer" encuentra el dispositivo y dale con el botón de la derecha, selcciona en donde dice formatear, selecciona fat (default) y eso te libera el espacio pero cuidado porque te borra la información.
despues de que hagas eso puedes meter toda tu música de nuevo lo único es que este dispositivo es de 2GB
17,179,869,184 .......... bits
2,147,483,648 .......... bytes
2,097,152 .......... kilobytes
2,048 .......... megabytes
2 .......... gigabytes
0.001953125 terabytes
0.0000019073 petabytes
0.0000000018 exabytes
una canción=entre 1500 y 6000KB
quiere decir que en tu dispositivo caben alrededor de 420 cancionesy a estos dispositivos no les puedes agregar mas memoria si quieres meterle mas música tienes que comprar un aparato con mas capacidad.
si te sirve el consejo dame un buen rating
gracias
How to put movies on an mp3 player
if its a small mp3 player you cant put movies but if it is a mp3 player with a usb that allows movies you just transfer it to the usb file by copy nad pasting
System file error , please help
It may be the batteries died and can cause this issue- it happened to me with different company MP3. If under warranty- use it.
How can i reformatt my
You can plug it in the USB then on your computer go to start then My computer it should show up under removable storage. Right cilck it then click format.
Wont sync to my computer and the computer will not recunize it
Go into the control panel, click on system, then device manager and then search the list and see if any red or yellow exclamation marks are present. If none are than unplug all your USB cables going to the computer. Next open up Universal Serial Controllers and uninstall all the devices listed, close the open windows and shutdown the computer, wait 10 seconds after complete shutdown and turn computer back on. Let windows boot completly up and it will reinstall all the USB drivers again and probaly have you reboot the system. After it boots back up install your software to your player, after installed than plug your player in and it should work. If it works OK than plug the USB devices you unplugged earlier back up 1 at a time, windows will detect it and load the required drivers again for each device you plug in. After all your devices are re-installed do a shutdown, wait 10 seconds and reboot. Everything should work normally now. I’m happy to help further over the phone at
https://www.6ya.com/expert/david_c087e4b7d13c0163
Coby MPC 895 - Some MP3 format songs will not play
i suppose your player is under a virus attack. clean it with an original antivirus software and also your pc too.reset your player to original factory settings. remember this will erase all your data in the device. so you can make a backup before formatting the device. that will solve your problem
