20 Most Recent GE 168947 Toaster Oven with Convection Cooking Questions & Answers
WE HAVE A GE 169104 TOASTER OVEN
Do you still need top elements or do you still have your GE 169104 oven?
1/3/2019 11:29:46 PM • GE 168947... • Answered on Jan 03, 2019
0answers
GE 169104
Be the first to answer 11/24/2011 12:40:25 AM • GE 168947... • Posted on Nov 24, 2011Be the first to answer
What is the electrical rating
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
6/17/2011 8:27:57 PM • GE 168947... • Answered on Jun 17, 2011
Dcan I get a part
Here is a GE address where you can check or there is a link to contact the company.
http://www.geappliances.com/service_and_support/
If that doesn't help then here is an address with a list of websites that carry oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
4/9/2011 6:45:40 PM • GE 168947... • Answered on Apr 09, 2011
3answers
How to use Rotisserie?
GE has the instruction manual online at: http://www.gehousewares.com/products/countop_oven_rotise_1066410585855.pdf
Make sure you look at the cook times. The manual suggests using a separate timer (I use my regular oven's timer if I'm not cooking anything with that at the time) I've been reading a lot of negative feedback about this product but I love mine and use it regularly.
4/3/2011 2:40:57 PM • GE 168947... • Answered on Apr 03, 2011
I just took my oven apart and confirmed that 1 of
Please press accept or reply
I can easily answer this question for you,
Bruce username is bbl242003
1/14/2011 3:06:36 AM • GE 168947... • Answered on Jan 14, 2011
No broiler heat
its not a diode its a fuse a high temp fuse . there is a number on it with a "c" after it thats the temp it opens ..... you can jump it out with a small bare wire just to test your elements and thermostat . if the thermostat does not cycle this fuse will blow . do not leave it jumped out , this is just for testing . find one on line with the number . and high temp fuse ... good luck
1/5/2011 2:49:26 AM • GE 168947... • Answered on Jan 05, 2011
0answers
The broiler does not shut off after timer is
Everything runs through the timer circuit. Basically, you will need to replace the timer. Order one from supplier and quote them the model.
5/18/2010 2:38:25 PM • GE 168947... • Answered on May 18, 2010
The top broiler element is not working
the broler element probably burnt out. it would not pay to fix.
2/24/2010 8:27:19 PM • GE 168947... • Answered on Feb 24, 2010
On my GE 169127 Toaster Oven, R2 on the 125301 DC
In my case I found a capacitor on the 9 volt motor control board blown open. It was rated for 250 v but no mfd rating. I called the 877-207-0923 option 4 number. The GE toaster is warrantyed for 2 years. I was able to exchange it for a newer model at the same price today. The new one checks out just dandy.
2/24/2010 12:51:04 AM • GE 168947... • Answered on Feb 24, 2010
Does anyone know where to get a repacement
1.888.261.3055
12/6/2009 10:26:02 AM • GE 168947... • Answered on Dec 06, 2009
Looking for a manual for a GE model #168947 c
I was just looking for a manual, no problem with the unit. But I figured it out, I was confused about the rotisserie.
10/3/2009 5:16:09 PM • GE 168947... • Answered on Oct 03, 2009
2answers
Where can I purchase a
TRY THIS http://www.walmart.com/catalog/product.do?product_id=2189051
10/2/2009 7:31:25 PM • GE 168947... • Answered on Oct 02, 2009
GE 168947 Toaster Oven with Convection Cooking Logo
61 questions posted
Top GE Toaster Ovens Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Toaster Ovens
  • GE Toaster Ovens
Most Popular Question
just took oven apart confirmed 1
  • Toaster Ovens
