20 Most Recent
General (102105011) Electric Kettle Questions & Answers
New GE electric kettle causes wall outlet to stop working.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
10/9/2017 5:59:04 PM •
General...
Answered
on Oct 09, 2017
Which brands of electric tea
Cuisinart, Breville, DeLonghi are some top brands works great for long time and very easy to use and clean.
Most of them have temperature control, cord free operation and good capacity.
Check out GroomNStyle.com for best reviews.
7/30/2015 7:27:50 AM •
General...
Answered
on Jul 30, 2015
Can kettle be cleaned and continue to be used.
I use a solution of vinegar and water (1:1) and boil it in the kettle, to remove mineral deposits from the metal heating surface (We do the same with the percolating coffee maker and run it through several times)... It seems to take any residual tastes out of the unit and possibly also cleans the plastic parts that it touches (I believe it does).
By the way... WHO thought it was a good idea to heat apple cider in an electric kettle. Sorry but WOW
7/30/2015 7:24:22 AM •
General...
Answered
on Jul 30, 2015
Why is this kettle so noisy
Kettles generally do this, Here's why: As it's heating up, the water next to the element turns to gas and starts to rise to the top. Since the gas bubbles are small at first, they turn back to water before reaching the surface and water rushes in to fill the space - this is what creates the noise. When the element gets quite hot, however, it can convert the water to gas more quickly which creates bigger bubbles that float to the top and burst into the air.
So, the longer it takes to heat up, the longer it makes noise. Some kettles have a more powerful element that simply gets to the second stage more quickly. The 'cordless' ones like yours have a smaller connection from the power to the element and it takes a bit longer. Worthwile, considering the convenience, in my opinion.
3/2/2011 11:52:23 PM •
General...
Answered
on Mar 02, 2011
Electric prong fell in vegetable oil. is it okay to plug in?
yes buy you must clean all the oil off first , use 409 spray or something like that , them dry for a day or so . it will be fine . dont give up on that old ge , it will last forever , you will never find a new one sold today thats as good as the one you have there .
good luck
5/25/2009 3:48:53 AM •
General...
Answered
on May 25, 2009
GE Model 168950 Electric Kettle base unit bad
di you try calling GE @ 1800-ge-cares ? dont except much but my parts book only says :PRIVATE BRAND GE , MADE IN CHINA , NO PARTS ORDERED , NO PARTS , 0 IN STOCK ...........
2/20/2009 3:45:00 AM •
General...
Answered
on Feb 20, 2009
BAD KETTLES
not news to me . i have a repair shop .i have this type come in once and a while . cannot be repaired , no parts made . made in china JUNK ! i would say buy another brand but there all the same . you might try a goodwill or e bay for a nice vintage one and have it forever . good luck
2/20/2009 3:40:52 AM •
General...
Answered
on Feb 20, 2009
How to descale tefal express boil
I was searching for this solution then I found the manual in a draw so to help anyone else with the same problem the method is:Descaling should be carried out every 3 months.Fill the appliance to max. Dispense maximum size cup to a large cup.Add descaler to the cup then pour back into appliance.Dispense the mixture in the appliance into the cup and disgard.Continue until applance is at minimum water level.Empty the appliance then refill with water and run it through the machine and disgard until its at minimum then empty the appliance again.It should be ready for use. You can use 1ltr white (and only white) vinegar instead of the descaler and water mixture.
Hi, Tefal performa Kettle Bimetallic disc is
I wish I could help, but unfortunatly there are no parts that can be purchased for this kettle, I would expect that TEFAL has a propriatary hold on these and you can only get them through TFAL. I would try e-bay and I will keep looking, but for some time now I have found no parts available.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
