20 Most Recent
Farberware (102105065) Electric Kettle Questions & Answers
The automatic shut-off has failed
The automatic shutoff is controlled by a thermostat situated in the base. To fix it you would need to dismantle the base and replace it.
Since this is a sealed unit no parts are available and the unit is not serviceable - if it fails you just get a new one since that will be cheaper than fixing the current one.
How do I open the can opener to install batteries
It looks like the top cover unsnaps from the end away from the can opener cutter wheel, then unhooks from the cutter wheel end.
I got this from https://www.youtube.com/watch?v=lOaMr3y6-n8 . Watch carefully from 0:23 - 0:38 to see how the cover goes on; from that you can infer how it comes off.
I am looking for a Farberware skillet power cord for model ZL208.
You may be able to find the power cord you need at a local or online store that specializes in replacement parts for kitchen appliances. You can also try contacting Farberware directly to see if they can provide you with a replacement power cord for your model.
I need a manual for a Farberware air fryer f919b
this is what ive found its probably what your looking for https://www.manualslib.com/manual/1212483/Farberware-Ccxm22.html?page=2#manual if not ill look more into finding one for f919b when i have time
I am grtting no pressure from my farberware 7in1 6 qt cooker
I'm sure you've done this - but make sure lid is on correctly - also check any sealing rims for foreign/stuck on foods that dried on. Could also be seal needs to be replaced. Best to buy these ahead of time as they do need to be replaced every so often.
If none of these contact manufacturer.
