20 Most Recent
Sony VAIO VGP-BMS33/B Questions & Answers
I have just upgraded from vista to windows 7 and
Simples.....The led may showing as there is power, but charge.change for new/recharged.
If no result, suggest you reinstall micky prog or access sony to see if your micky prog has update for win7?
Pairing code of Sonay Vaio VGP-BMS21?
Try this
> (Go To) Control Panel > Bluetooth Devices
If your device is already there
Highlight device then in menu bar select Remove Wireless devise
Click on Yes
When device removed or if it was not there in the first place
> Add Wireless Device
When computer finds your device select it
Click on Next
Choose Pair without CODE
Click on Next.
Computer should then install drivers
This works with my Sony VGP-BMS33
Laser mouse
NOTE: This mouse never came with any software in the first place.
To get the mouse to work again proceed as follows:
Open Control Panel > Bluetooth Devices>Select VPG-BMS33 >Bluetooth Settings>Options> place a tick in the "Allow
Bluetooth devices to find this computer">Apply>OK then close the open window.
The mouse should now work.
If this does not fix the problem then try this:
Go to Control Panel click on Bluetooth devices. Select VGP-BM133 (your mouse) then select Remove Wireless Device. After it has been removed NOW Select Add Wireless Device ( your computer will search for the mouse) When it finds it and it appears in the window, select it and then select Next. The computer will load the drivers for it and after you close the window the mouse should work.
Note often when my mouse has stopped working it has been because the batteries were flat and all the above fixes would be to no avail.
Laser mouse
Insert the bluetooth receptor available with it into one of the usb ports.
