20 Most Recent Black & Decker CTO649 Toaster Oven with Convection Cooking Questions & Answers
2answers
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
4/10/2016 10:11:34 PM • Black & Decker... • Answered on Apr 10, 2016
2answers
Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
10/2/2012 10:54:44 PM • Black & Decker... • Answered on Oct 02, 2012
2answers
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
4/4/2012 2:57:13 AM • Black & Decker... • Answered on Apr 04, 2012
0answers
Bad fuse
Be the first to answer 11/11/2011 12:45:02 AM • Black & Decker... • Posted on Nov 11, 2011Be the first to answer
My toaster oven has no power
This can be due to three reasons:
1. It can be fault in the wire to the oven, if the plug is faulty or the wire has opened out.
2. Secondly if the switch to activate the heating coil is bad it will not connect the power to the coil
3. Finally if the coil is OPEN , then it can be checked using a multimeter as also the wire connection to the heating coil.
8/25/2011 7:02:31 AM • Black & Decker... • Answered on Aug 25, 2011
Black and decker countertop convection oven not
Need to know how to be able to take oven apart to get to switch to test it.
6/12/2011 1:27:59 AM • Black & Decker... • Answered on Jun 12, 2011
I can't find a manual
Sometimes putting in too much info will hurt a search. I found this link for the manual. Let me know if this is what you are looking for and thanks for using FixYa.
http://www.retrevo.com/support/BlackAndDecker-CTO649-Ovens-manual/id/20075ag408/t/2/
2/2/2011 10:03:30 PM • Black & Decker... • Answered on Feb 02, 2011
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
5/20/2010 8:50:41 AM • Black & Decker... • Answered on May 20, 2010
My black and decker toaster oven is less than a
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
5/7/2010 6:26:41 AM • Black & Decker... • Answered on May 07, 2010
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
5/7/2010 6:12:33 AM • Black & Decker... • Answered on May 07, 2010
The timer doesnt't ding, and the oven does not
Hello :
You need to check the fuse . If the fuse is OK , then the proplem will be with the power PCB [ printed circuit board ] . You need to call for repairing if the problem is with the PCB .
regards .
please rate !
3/28/2010 8:03:53 PM • Black & Decker... • Answered on Mar 28, 2010
3answers
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
12/13/2009 10:24:25 PM • Black & Decker... • Answered on Dec 13, 2009
I have black decker toast R.oven.it is two knock
Sounds like a direct short within the oven! If the unit is still under warranty, take it back to place of purchase!
7/23/2009 8:34:18 PM • Black & Decker... • Answered on Jul 23, 2009
Black n' decker oven toaster oven broken
I work for Black & Decker customer service. Our number is 800-231-9786.
Unfortunately, our products can't be repaired. Please call the above number so that we may determine your warranty eligibility. The oven carries a one year warranty from the date of purchase.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
7/4/2009 6:50:52 AM • Black & Decker... • Answered on Jul 04, 2009
Black and Decker 0650
I have a Black & Decker CT0649 toaster oven. The timer switch on the toast control does not work and I took it out and took it apart. There is no way I can put is back together. Black and Decker will not sell me a new one!
If you have a broken Black & Decker CTO649 I would be interested in purchasing the two timer switches in it before you through it out, $5.00/each. (Negotiable).
I can be reached at [email protected]
Thanks
Al
5/13/2009 11:25:41 PM • Black & Decker... • Answered on May 13, 2009
Black & Decker CTO649 Toaster Oven with Convection Cooking Logo
39 questions posted
Top Black & Decker Toaster Ovens Experts
john h
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Toaster Ovens
Most Popular Question
find manual
  • Toaster Ovens
