20 Most Recent
Anthology Solutions Yellow Machine P400T (250006001) 400 GB Network Hard Drive Questions & Answers
Yellow machine power out won't restart
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
3/10/2014 2:52:28 PM •
Anthology...
Answered
on Mar 10, 2014
Yellow machine server.
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
4/28/2010 12:00:55 AM •
Anthology...
Answered
on Apr 28, 2010
I have a yellow machine p400t and i need to give
Yes, it must be attached to the network
0. Install the yellow machine software on the PC
1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8.
2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears.
3.Click Edit.
4.Select Yes to Enable LAN Interface. Default: Yes (Enabled)
• If you select No, all other LAN option fields are blocked.
• If you disable the LAN Interface, the only access to the Yellow Machine appliance is
through the WAN port. Anthology Solutions does not recommend this configuration.
5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled)
6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address
• Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine
appliance connects to either a router that has DHCP service enabled or to a cable
modem. This setting makes the Yellow Machine appliance a DHCP client on your
network.
• Obtain IP Address from ADSL provider is greyed out.
• Choose Static IP Address if your network is locally defined and controlled and does not
use DHCP services. Type the IP address manually.
7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply.
8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
4/25/2010 5:39:52 PM •
Anthology...
Answered
on Apr 25, 2010
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
