20 Most Recent Vestax PDX-2000MKII PRO Turntable Questions & Answers
2answers
Vestax pdx-2000mkiipro keeps blowing internal fuses
You have a short in your unit, and you will need professional assistance in determining the cause. You might also want to try a different outlet. If it fails, then you'll need to bring it to a service center for repair.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
1/7/2015 2:20:50 AM • Vestax... • Answered on Jan 07, 2015
How to remove the platter from the turntable?
Take a a look at the platter, see any screws: unscrew them?
11/1/2014 9:50:31 PM • Vestax... • Answered on Nov 01, 2014
Torqe is too low of motor
well what'scthevmax torque you can get
10/3/2014 2:21:20 AM • Vestax... • Answered on Oct 03, 2014
How do you take the plastic clip off that hold the tone arm
Well be very carefull, since they breal soooo easily. You can get if bu unscrewing the imbuscat the side and the internal you desolder your tonearm wires and with some effort you can pull out the pivot after unscrewing the the height adjustment screw at the the side. They are crappy things and i just glue them together woth some thin bare thin wire to keep it in place, after that i use some kevlar/carbon fibre with the right glue, but not a lot of glue holds on it.... annoying part.
8/21/2014 4:10:43 AM • Vestax... • Answered on Aug 21, 2014
My vestax turntable doesn't spinning
Well since i read it often and have such a table myself, it,probably like with technics turntables. A lack of maintenance and since you s ratch with it it , only never replacing the powersupply capacitors, which are really good , but it depends all on the pressure you use . Open the unit , check the capacitors, which is 10sec work , offcourse check the fuses and thermistor , but do you see a light if you put it on and do you hear crackles when you spin the platter and have you ever ipend the motor and clean and lubricated the motor? A lot of peoples with the 2000 blame the motor and transformer for the thing do stop, without never have opened the unit in 14 years. It's a perfect motor and powersupply, but first open the supereasy tt checking the obvious things. But you have to agree, it's a nice scratch unit, als the 3000 mix, which has way better abs plastic and feet, scratches better then my mk-5. And replace the plastic in the feet for mettal. I see a lot of guys with broken feet and a whole deck with scratches, but though i agree that the height adjustment, piece of far to hard plastic toyshit, most peoples use the pitch far too high, But in 14 years stuff breaks
8/15/2014 6:21:32 PM • Vestax... • Answered on Aug 15, 2014
Platter is rubbing against sides of turntable, making a grating sound. How can I fix it?
Remove the plater with the two screws and bow the two pieces of metal where you screw your platter on a bit to above. If the ain\'t it , check the screws where you engine is connected with on the inside and otherwise the rottor holder ain\'t straight anymore, so just inscrew the backplate of the motor , heat that shitty glue , which can be a hell to remove and the pieve of the where the rotor spins on , needs a couple of tick with little hammer in the middle , which will raise the rotor and you have more space.... don\'t hit it to hard and only till it\'s straight. gr richard
6/22/2014 11:00:38 PM • Vestax... • Answered on Jun 22, 2014
2answers
My turntable keeps skiping for no reason, no
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
6/14/2014 10:33:26 PM • Vestax... • Answered on Jun 14, 2014
Platter on my CR249 is distorted, not level
Is it made of plastic, it is probably warped. Put it on an flat table to check; both sides. If that's not the issue, it could be a spindle bearing bad or loose. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
12/17/2013 3:01:25 AM • Vestax... • Answered on Dec 17, 2013
0answers
My turntable spins but has no sound output. the
If you disconect the wires to the cartridge you can check if the sound is getting to the amp. With the amp switched on and the turntable connected, touch each wire one at a time with your finger. You should get a buzz on one wire on the left and one on the right with another. The other two wires won't give off any buzz. If you don't hear the buzz on either channel, either the connections linking your amp are faulty or the magnetic cartridge pre-amp inside the amp has failed. If you do hear the buzz then the cartridge is faulty or the connections to it are bad.
11/20/2010 12:11:24 AM • Vestax... • Answered on Nov 20, 2010
MY FUSE KEEPS BLOWING OUT
If the fuse keeps blowing it's because some part is acting like it is a piece of wire. It will probably be a semi-conductor in the power supply of the turntable, or the transformer. They often look burnt or damaged the semi-conductors in this state.
11/19/2010 11:58:08 PM • Vestax... • Answered on Nov 19, 2010
2answers
Re: Power Problem
More than likely the power transformer fried. If so, it will need to be replaced. You might also want to check the fuse. Some of the PDX units have fuses on the rear (where the RCA cables connect)... some don't. I've also seen some that have a fuse on the inside of the turntable, underneath the turntable platter... some don't. If your's has a fuse, see if it has burned out. If so, just replace.
If not, then the only other thing that would affect power on the PDX is the power transformer, and only a qualified service tech should replace this for you.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
3/14/2010 10:18:01 PM • Vestax... • Answered on Mar 14, 2010
Prongs in the Tonearm
youll probly wanna by a new tone arm mate,u could try an straighten them but youll never really get em spot on or youll damage them.gd luck
8/7/2009 2:06:28 PM • Vestax... • Answered on Aug 07, 2009
What is the weight of a Vestax PDX2000?
About 26lbs
7/24/2008 9:20:17 PM • Vestax... • Answered on Jul 24, 2008
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
7/24/2008 9:19:48 PM • Vestax... • Answered on Jul 24, 2008
Turntable speed problem
i find that if i switch everything off and then unplug the main power the deck then works without lagging.
6/10/2008 9:53:34 PM • Vestax... • Answered on Jun 10, 2008
Vestax pdx 2000 loose to the touch deck
It is possible that the deck that feels loose is not properly secured to the turntable. You may want to try tightening the screws or bolts that hold the deck in place. If this does not fix the issue, there may be a problem with the bearings or the motor of the turntable. It is best to consult a technician or the manufacturer for further assistance.
1/8/2023 5:33:08 AM • Vestax Audio... • Answered on Jan 08, 2023
Vestax PDX-2000MKII PRO Turntable Logo
Popular Tags
20 questions posted
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Vestax Audio Players & Recorders
Most Popular Question
prongs in tonearm
  • Audio Players & Recorders
