20 Most Recent
PNY GeForce 7600 GS, (512 MB) AGP Graphic Card Questions & Answers
GE force 7600 gs
Unistall this unit and reboot ,
if the problem still exists then back up the info you need and then consider formatting this unit
or
restoring it back to an earlier time before the card was introduced,
either solution will fix the problem,
Now that everythings working again search the model of the card you have and read about the card specs and or the reveiws about the cards ratings,compared with your computers specs,
More ram may be required for the card to perform properly,
once back to normal,
then try to reinstall the card again,hope you got the disk?
If it turns to custard again then consult the store you got the card from and ask them to demo the card for you.
or
you demo it to them.
WARANTEE ISSUES..........Consumers have rights.
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Installation cd
go right to their website and download the appropriate driver/software and install it from your computer instead of the cd. incidentally, remove the cd from the drive and inspect the working side... the shiny side and see if it has any smudges or scratches. the cd player may not be able to read it.
it's not mentioned but is that a pc or mac and what operating system are you using ?
Robert
Geforce gt 630
Ok, so when you put the card , even at start you can't see nothing or just at windows start ?
