20 Most Recent kawasaki 19.2V 4 Piece Cordless Tool Kit Questions & Answers
Where can I get a schematic for my Alltrade Kawasaki 19.2V battery charger, one of the transistors is bad
Following I think I have the same problem
3/17/2023 12:33:27 AM • kawasaki 19.2V 4... • Answered on Mar 17, 2023
Where i can purchase 19.2v adopter and charger
Where i can purchase 19.2v drill adopter and charger in bangalore
6/24/2014 4:16:15 AM • kawasaki 19.2V 4... • Answered on Jun 24, 2014
2answers
The charger does not charge the batteries, the
You can go to AllTrade tools and search your tool. If your model number is affected there is a recall notice on Kawasaki tools. They will send you a new charger kit, transformer and base.
5/29/2014 9:30:23 PM • kawasaki 19.2V 4... • Answered on May 29, 2014
4answers
Kawasaki 19.2 cordless drill
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
1/20/2014 8:05:12 PM • kawasaki 19.2V 4... • Answered on Jan 20, 2014
I need a charger
I will sell my charger. My motor went out on my drill. [email protected]
6/2/2013 3:10:17 PM • kawasaki 19.2V 4... • Answered on Jun 02, 2013
Batteries will no longer take
My motor went out on mine. I have two batteries I will sell. [email protected]
6/2/2013 3:09:20 PM • kawasaki 19.2V 4... • Answered on Jun 02, 2013
Where can i get a
I have a trigger out of a new drill. My motor went out. Do you want to purchase the switch? [email protected]
6/2/2013 2:58:06 PM • kawasaki 19.2V 4... • Answered on Jun 02, 2013
2answers
The drill "runs" without any
Try tapping on the sides of the drill to see if that fixes your problem. If not then you might try to get ahold of Kawasaki and see if theres anything they can do under warranty.
11/3/2012 3:09:19 AM • kawasaki 19.2V 4... • Answered on Nov 03, 2012
Where can I get a
Call the service # and they will send you a new drill, mine had a burn mark right through the switch and with the model # they replaced it mine was a21.6 they are having troubles with the triggers i pulled mine a part and when i put a battery in it it would run continuous , the number should be on the drill1-800 590-3723
11/2/2012 2:20:57 PM • kawasaki 19.2V 4... • Answered on Nov 02, 2012
4answers
Kawasaki 19.2V Battery
Danger!!! There is a RECALL NOTICE in effect for batteries and chargers for Kawasaki 19.2v systems. Go to the website and check your model number and they will ship you a free charger, if your model number is affected, RECALL NOTICE
5/14/2012 9:18:22 PM • kawasaki 19.2V 4... • Answered on May 14, 2012
When the charger is left
when the battery is fuly charged if im not mistaken the green light will still stay on but will not be charging the battery anymore. All the light is doing is indicating that the battery is fully charged. It is not recommended that you leave the battery sitting on the charger for long periods of time since batteries an get a memory from a charger and then you might start having some battery issues. Hope this helps.
4/18/2012 11:06:31 PM • kawasaki 19.2V 4... • Answered on Apr 18, 2012
Having charged both batteries the
Hi there, let me see if I can help.
1.Since this is a 4 piece kit, test the batteries in some of the other tools to make sure the batteries are good
2. This could be a malfunctioning unit, If you just bought it, take it back to the store and get a replacement, (you may have to take in all 4 and do a complete swap but most home improvement stores have no problem doing this)
3. The Forward and Reverse selector just above the trigger is stuck in the middle meaning, the drill is not in forward or reverse and when you press the trigger nothing happens. See Page 15 of this PDF for more information.
4. If none of this works, there is a Recall for that Battery Unit. Check This PDF to see if what you bought applies.
Hope this helps.
Brian
5/25/2011 12:45:48 PM • kawasaki 19.2V 4... • Answered on May 25, 2011
Drill chuck locked up
Your problem is with the screw holding the chuck onto the shaft. That screw if a reverse thread and needs to be tightened in reverse direction.
1/28/2011 1:04:54 AM • kawasaki 19.2V 4... • Answered on Jan 28, 2011
My husband has a Kawasaki
check voltage on batterys with volt meter if the batterys are weak try recharging. try them in flashlight or other peice of equipment.. try moving forward reverse switch while pressing trigger and maybe clean battery contacts with eraser.
1/16/2011 6:36:28 AM • kawasaki 19.2V 4... • Answered on Jan 16, 2011
2answers
My Kawasaki 19.2v battery does not hold a charge
sounds like your connections from battery to charger are dirty not making contact when did you buy it?
12/19/2010 1:36:53 AM • kawasaki 19.2V 4... • Answered on Dec 19, 2010
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
58 questions posted
Top kawasaki Drills Experts
Sean Wright
Sean Wright
john h
Steve Pack
Steve Pack
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
View Most Popular
kawasaki Drills
  • kawasaki Drills
Most Popular Question
get
  • Drills
