20 Most Recent
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Questions & Answers
I have the Lacie Minidisk
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to
an attached USB storage device. This way, if files on the Ethernet Disk
mini are damaged or accidentally deleted, you can restore them to their
original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your
Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back
of the Ethernet Disk mini, just like you would connect the external
hard drive to your computer.Confirm that the drive is
properly connected. Log in and click on the Administer HipServ link.
Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to
the external hard drive and click on the disk icon in the "Backup"
column of the file list.When you back up files to MySafe, the
Ethernet Disk mini duplicates the file path in MySafe so that everything
you back up is organized in MySafe just as in its original location.
So, if you copy a file from MyLibrary, a MyLibrary folder will appear in
MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage
before unplugging your MySafe external hard drive. Wait for the
interface to change and for the Use Drive button to appear before
disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before
disconnecting the USB cable can cause data loss and/or damage the drive.
Always use the Safely Remove Drive feature when disconnecting an
Hello. I have a LACIE
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here:
http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here:
503-844-4503
[email protected]
Please leave feedback for this answer, thanks.
I cannot connect my
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
LaCie Ethernet Disk Mini 500GB
i try repair this model on customer, but this has some encript software, i change the control board inside, but i need to format hdd, because was unreadable, try call Lacie they say "the product is old consumible part, whe have new models to sell". Consumible is "if is on waranty period, change for a new,if not buy a new unit"
Light flashing with clicks
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Not turning on.... I turned
Same problem. Bought a new power supply at extortionate price from Lacie but still no joy. I'm hoping to find a way of converting to a dumb external USB HD.
I have a Lacie Ethernet mini Disk, 500GB, attached
If you connect with ethernet lan cable then make sure it is in network.
If you are not able to access it in lan then connect harddrive with computer with usb cable then install driver from disk then if still not recognize then make sure harddrive inside the Lacie case is working fine.
If it gives sound like clicky noise then you need to fix the error on harddrive.
But if you are able to access harddrive with usb cable then your harddrive is fine just check network settings of harddrive and make sure lan cable is working fine.
Thanks for using FixYa.
My external hard drive does not start. I can hear
Goto control panel/ admin tools/computer management then disk management now with a bit of luck you should see your drive. Right click it and give it a new drive letter, hopefully now it shows in computer and u can get all of your data.
I can't connect to Edmini via LAN nor USB.
Just contact
www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
- Move the power switch to the OFF position. Wait for the drive to shut down.
- Turn ON the drive.
- Within about 3 seconds, flip the switch OFF and On several times.
- Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both
admin.)
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
It wont recognize on the computer on any type of
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
