20 Most Recent
Epson P-5000 Digital Media Player Questions & Answers
Epson P5000 won't switch one
You have possibly damaged or disturbed internal connections which only an engineer can fix due to fiddly parts and a dust free environment, It hinges on the cost of repair?
Check on ebay etc to find its current value and use that as a guide to compare with a repair quote, if its not worth it put it up for auction to recoup some cash against a new one.
All you can do is check any removable parts battery, card etc are secure, their internals are frail to damage. Check for home contents policy against accidental damage?
Sorry, hope this helps...................
My device keeps rebooting when a CF card is
HI and thank you for your purchase.This is indeed a serious issue. I have a couple of questions to post before i render a proper solution.1. Where there any error messages or symbols displayed during this occurrence?2. Has the unit been dropped or mishandled, improperly recently?3. Have you updated your firmware, recently to the most recent form?4. Dose the unit reach high operating temperatures during this occurrence?Please answer as clearly and direct as possible.Standing by..
Epsom p5000 will not turn on
i just solved this problem by connecting it to an a/v output (in my case, a TV). it works well on the TV screen and when i pulled out the jack, my viewer's screen when back to normal.
Wont connect to PC
After two different calls and a couple of hours on the phone with Epson, my problem had a very simple solution. Vista had not assigned a drive letter to the P-5000. I simply had to assign a drive letter and it's now working fine.
By the way, the first call to Epson ended with their Level 1 support guy telling me I needed to call Microsoft! Needless to I wasn't happy with that answer and let him know it. :D
How do i get my craig cmp1226e to advance to the
the little wheel at the top on the left side roll it to the right to advance to the next song. hold it to the right to advance quickly, and roll it to the left to go to the previous song. Push it straight down to get to the roo menu.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
