20 Most Recent Sony VAIO VGN-TXN15P/B Notebook Questions & Answers
I have a three year
it is asking for a log in name or password if you never used one try just hitting the enter key to see if it moves on in the process unfortunately unless any one else has an answer , you may have to take it to a computer repair shop and have the problem properly diagnosed
3/18/2017 8:34:57 AM • Sony VAIO... • Answered on Mar 18, 2017
The volume buttons on the
What operating system do you have on the Vaio? Check if there is some options in Control Panel - Sound menu...
9/19/2011 10:02:55 PM • Sony VAIO... • Answered on Sep 19, 2011
Boots up but black screen
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1.Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2.Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3.Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4.Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5.Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
9/5/2011 6:23:54 PM • Sony VAIO... • Answered on Sep 05, 2011
I have a sony FGN-TXN10
Have a read on this website it has all the answers to your problem http://www.computerhope.com/issues/ch000646.htm good luck with it from Scott
9/2/2011 11:21:39 PM • Sony VAIO... • Answered on Sep 02, 2011
I pruchased a Sony VAIO
Did you tried cable connection to your router to see if this works?
which windows its runing on?
If wireless connection drops its not all the time your laptop issue... its router transmitted channel conflict with laptop wireless card channel....
You might fix this by changing the router wireless setting by changing the transmission channel on it.and then re connect the laptop or it may auto reconnect with it and hopefully signal will not drop.
one is network card for cable connection to internet
one is wireless card for wireless connection to your router(with internet connection)
I will write more after I get your reply. As I am in the middle of my own issue now... ;)
5/8/2011 12:02:35 PM • Sony VAIO... • Answered on May 08, 2011
2answers
Dvd-rw is not recognizing cd
Place another CD in the tray one that works you know works if it recognizes it possibly it is the CD that you are trying to insert is bad or broken. So try any other one a movie disc that works if it picks it up that would be my first thought if it does not then you may need a new CD-RW burner for the lap top they are not that expensive. This does happen I have changed a few of them out myself. John
1/28/2011 4:43:14 PM • Sony VAIO... • Answered on Jan 28, 2011
Hi my sony vio vgn
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
12/9/2010 7:56:40 AM • Sony VAIO... • Answered on Dec 09, 2010
3answers
Replaced screen still black but
Then you have a faulty Power Inverter.. You need to replace the power inverter below the screen... it is the Long rectangular Circuit board - it is what the lcd wires/plug plugs into.. it converts the DC power going through your laptop back to AC Power to Be able to power the bulb..They average $12 to $30 on Ebay for replacement... just unplug from both ends ( display cable plug and lcd bulb plug ) When Searching on Ebay... type : sony vaio vgn-tx power inverter
10/6/2010 3:20:33 PM • Sony VAIO... • Answered on Oct 06, 2010
I reformatted the hard drive and reinstalled
You will need the drivers for the drive. When you look at the devices in device manager (devmgmt.msc) do you see any drives under DVD/CD-ROM drives?
3/6/2009 2:53:51 AM • Sony VAIO... • Answered on Mar 06, 2009
Ethernet port jumps off and on
Visit support site and download latest network driver for your model.
12/10/2008 1:31:34 AM • Sony VAIO... • Answered on Dec 10, 2008
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Pci modem drivers and audio drivers
Check this Sony's website: Original Drivers Package
10/9/2018 8:31:43 AM • Sony VAIO... • Answered on Oct 09, 2018
Sony VAIO VGN-TXN15P/B Notebook Logo
Popular Tags
18 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
replaced screen still black but
  • Computers & Internet
