20 Most Recent
Archos 604 Digital Media Player Questions & Answers
Hello i have a problem
Sounds like the hdd has dislodged due to the knock...open it up pull off the hard drive...reconnect it..or reseat the connection..and try again...if that doesn't work...you could try removing the drive to run a chkdsk facility using Linux on a pc...or source another hdd off eBay with the correct file system and drivers...for that model.
12/16/2017 11:23:26 AM •
Archos 604...
Answered
on Dec 16, 2017
Archos 604 dvr blank screen
It sounds to me like there's an Component A/V cable issue. Please re-check the cable connections making sure they are connected correctly. When using the docking station and Component A/V cables you must be sure the cables are connected with their corresponding colors on the back of the DVR Docking Station. Also check that the format of the recording is compatible with the "TV Standard" in the settings menu of your Archos. It will be either NTSC (USA) or PAL (Europe). Be sure to check the Video Output Settings of the Archos to be sure it is set to the same type of cables you are using- component, RGB, s-video or composite. Good luck!
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
How do i downloan from archos604 to my computer
Connect it to the USB port of the laptiop with the cable supplie with the 604. A popup will appear on the Archos screen - select the firts option. The Archos will then be visible to your laptop as an external hard drive. You can then drag files across from the Archos
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Lines across tv when using archos with dvr
SOunds like a problem with the connection between the dvr station and the tv. Ensure all connections are insered fully and dust free. Also ensure that you have set the output signal to PAL if using in Europe - do this via the setup menu
Can I charge archos 604 batteries using dvr
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
HOW CAN I DOWNLOAD MUSIC VIDEO AND VIDEO TO MY
screw that software. When you plug in the archos the archos asks what your doing with it. Say Hard drive mode and then you can drag and drop and file you want onto it.
Its pretty simple put movies in the movies folder and mp3s int he music folder lol.
When i connect my archos 604 to the computer my
Hi, ensure your Archos is already turned on before plugging in the USB cable and select HardDrive Mode on the pop up notice. If this dosn't work, once your Archos is ON and plugged in to your computer, press MENU on your Archos and select USB then HardDrive Mode on the next screen. Hope this helps, Shaz
