20 Most Recent
Westinghouse LTV32W6HD 32 in. LCD Television Questions & Answers
I HAVE THIS TV AND
The tv have three colors guns Green,Red,Blue.Pink pictures mean there no blue color.Take another tv tries that incomming broadcasting signal cable,see if u getting all three right colors for that tv?Yes,than that tv have a pink pictures have a dead Tuner signal board,no than u have a bad incomming broadcasting signal cable or pay cable box.If it the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
How can i fix this tv ?
Backlight problem. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
My son bought this TV and had it hooked up to a
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
A breaker blew in my
not on a surge protector is it? could be tripped....if not, it should have been. some have a built in breaker, unplug it for a couple of minutes and plug it in and try it.
