20 Most Recent
Sharp LC 37D62U 37 in. LCD HDTV Questions & Answers
The power light blinks 12 times and the screen never turns on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sharp LCD tv model 37d62u only half screen is working
You have a flew tab issue ( where the circuitry attaches to the screen) which is located under the screens top frame section. Or there could be a blown resistor or didode on the small board the flex tab attaches to also underneath the top frame section of the screen assembly
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Maximum volume on the set is too low!
On some cable boxes they have their own volume control. Raise the volume on the box if you can. if the volume on the tv is up all the way it should be loud. It should not be the tv if you have volume already coming out. try hooking up a dvd player or some other device and see if you have the same result
