20 Most Recent
Konica Minolta Di3510 Copier Questions & Answers
C0500 error code
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
C-0500 code mean no power to the fuser inside mid cover front is a micro switch that provides the power to the fuser unit Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How to delete saved addrese
You need to log onto the web interface, you do this by entering the I.P address into your search bar of your explorer and then you can go to the store address tab and you can edit and delete from there.
How to use scan
you need to give a LOT more detail than this. Include all hardware info both for pc and scanner/printer as well as operating system, and any scanner software you may have.
C0500 error code
Hi, Sir;
I believed this machine come with two heater lamp, change this two lamp position, and also thermistor have to be contact heat roller perfect, try it see what happen. good luck
Hi
I need a help i hav error code C-8003 on konica Minolta B951. Please assist.
Thanks
Podtermistor wa?ka utrwalaj?cego nie
wykrywa wymaganej temperatury w ci?gu 30 sekund.
po rozpocz?ciu cyklu rozgrzewania; dlatego
kopiarka nie ko?czy cyklu nagrzewania.
• Temperatura wa?k?w utrwalaj?cych nie
osi?ga wymaganego poziomu nawet po
up?ywie ustawionego czasu podczas cyklu nagrzewania.
Sprawd?, czy lampka utrwalacza H1 zapala si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji W?., w razie potrzeby popraw lub wymie?.
Sprawd?, czy H2 w??cza si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji ON, i w razie potrzeby popraw lub wymie?.
Sprawd? instalacj? TH1 i TH2 i
w razie potrzeby popraw lub wyczy??.
Sprawd? dzia?anie TH1.
Usu? CN80 (4P), a nast?pnie sprawd?, czy rezystancja
na CN80-2 i -3 na termistorze jest
niesko?czona.
5
Sprawd? dzia?anie TH2.
Usu? CN81 (4P), a nast?pnie sprawd?, czy rezystancja
mi?dzy CN81-2 i -3 na termistorze jest
niesko?czona.
6
Sprawd? ci?g?o?? H1.
W razie potrzeby popraw lub wymie?.
7
Sprawd? ci?g?o?? H2.
8 Zmie? PU1 - -
9 Zmie? PWB-A
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
