There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows based PCs. Be sure that you want to delete everything this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot".
Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Hope this helps.
There are several ways to speed up your PC by updating various components. Maxing out your memory capacity is one way, getting rid of files you no longer need is another because as your hard drive begins to fill up the system has to sort through all of these files to find what you want to access. You can defragment your hard drive and it will make accessing those files a little faster but maybe not enough for you to notice. You can defrag by clicking on the start menu click on programs and find the accessories folder click here and then again on the system tools folder, here you will find the defragmentation program and upon clicking it, it will let you analysis your hard drive and then defrag it. If you have not maxed out your memory to the 4-gigabyte max, I recommend doing so. In addition, you might consider upgrading your graphics card as well as going with a larger hard drive. All of these suggestions depend on why you need more speed, is it for playing games, movies, pictures? Another thing is that there are programs that constantly are working in the background that can also slow your system down. In the lower right hand corner there are usually icons there, these are programs that are running in the background whether you use them or not. Some programs such as Yahoo Messenger and some others are set to start up with Windows by default when you install them so you may want to disable them from doing so and start them only when you use them.
81 questions posted
1,757 Questions
347 Questions
315 Questions
269 Questions
198 Questions
