20 Most Recent
Panasonic KX-TG5672 Twin Cordless Phone Questions & Answers
Caller id
Call Customer Service 1-8O5-465-751O To Fix Issue
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
8/26/2019 9:30:46 AM •
Panasonic...
Answered
on Aug 26, 2019
Extension stopped working is there a setting on the base
Anytime the extension stops working, it is generally caused by a dead battery (90+% of the time). It is occasionally caused by the extension base not charging the battery. Try to pay attention occasionally to the charge status on the extension phone.
Buy batteries on Amazon. They're much cheaper.
12/27/2014 4:44:18 AM •
Panasonic...
Answered
on Dec 27, 2014
How to turn off the voice mail? Answering machine
Turning the answering system
on/off
Press {ANSWER ON} to turn on/off the
answering system.
LWhen the answering system is turned
on, the ANSWER ON indicator lights.
off, the ANSWER ON indicator turns off.
This info can be found on page 36 of the manual which can be downloaded from the Panasonic website.
9/30/2013 3:10:32 PM •
Panasonic...
Answered
on Sep 30, 2013
Line
It's only a single-line phone.
6/6/2013 9:42:51 PM •
Panasonic...
Answered
on Jun 06, 2013
How do I select the
Hello
You can adjust the count of rings of your phone. For this, press [0,6,1] as code and then press how many rings you wants. For instance, if you want to hear 7 rings press digit '7'. Upto 7 rings can only be set. You can select this number from '1' upto '7'. The normal factory setting for ringer number is '4'. OK.
9/5/2011 12:44:12 PM •
Panasonic...
Answered
on Sep 05, 2011
I am talking on phone;
sounds as though there is a problem with the speaker phone portion of the phone make sure you are not touching the button during the call. sounds as though you hitting that button during the call
8/25/2011 2:10:34 AM •
Panasonic...
Answered
on Aug 25, 2011
