20 Most Recent
Sony Handycam DCR-SR100 Camcorder Questions & Answers
Sony dcr-s100 says format error
Try another drive and see if does the same thing. If so your unit is bogus. If not, the first drive is bogus and maybe a format will restore it. Not like you have much choice.
How to fix hdd format error?
on the menu screen push the "show other" option then scroll down "manage media" scroll down you can see media format in this menu, push this option there will show two options 1, HDD 2nd one is memory card here you select the HDD the screen will show "Format?" All data will be deleted. here you give "yes" another dialogue will appear "are you sure?" here you give yes, finally will show executing then press ok.
My new Sony DCR-SR68E shows
SonyDCR-SR68E HDD Format errorGo to Menu-Show Others-Media format-HDD-Yes-Yes-okyou must be solve your problem.Never format your camcorder with NTFS or FAT system format using your operating system Windows.
E:61:10
The error e:61:10 signifies a stuck internal lens. Shut it off and tapping it on the side might work. If not you could have it repaired. In that case you may as well buy a new camera. Sorry.
The camera lists error code
Memorycard usually get corrupted while transfering data from devices like digitalcamera, mobile phone and computer. However, you can
recover data from memory card with
memory cardrecovery software.TenorshareData Recovery is a powerful data recovery program that can recover lost,formatted, corrupted, misplaced or accidently deleted pictures, videos, music,etc. from memory card, memory stick, SD card, CF Card and so on. You candownload it and scan your memory card for free to preview whether your datacan be recovered. Get it from
http://www.any-data-recovery.com/product/datarecoverystandard.htm
Sony dcr-sr100 will not turn on
This is usually caused by a failed component in the power circuit within the camera and will require disassembly and trouble shooting to narrow down the cause. This can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony handycam DCR SR65 HDD format error E31:00
Recently purchased a camcorder DCR-SR68 and we took all our wedding video
on it. It now says HDD format error and all my video is gone. I tried
resetting didn't work, took out the battery, didn't work. Sony told me
to format the drive but that also not function. couldn;t format that.
Is it possible to recover this video??? can i solve that problem?
please send to solve that problem
I have a Sony Handycam
I'm sorry that the Camcorder is displaying the "DATA ERROR" message.
You can find the HDD FORMAT option under the HDD Set Menu.
If the issue persists after performing the HDD FORMAT, try resetting the Camcorder using the RESET button located behind the LCD panel. You can locate the RESET button from the below picture.
If the issue persists after Resetting, service many be required. Please click hear to locate the Service Facility near your area to setup a service.
Thanks for understanding.
Please let me know if you require any clarifications.
Cannot find software disc
Try downloading the software you need on this site. Just follow the instructions there....
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=DCRSR100
When I turn on camcorder
This error may occur if data becomes corrupt on the camera hard disk drive. To resolve this issue, it will be necessary to format the hard disk drive and reset the camera to factory specifications.
NOTE: If model-specific information is required for how to format the hard disk drive or reset the camera, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
Performing the recommendations above should resolve the issue. If you have completed all of the recommendations and the issue is not resolved, service may be required. Click the Repair & Status link on this page for available service options.
Refer the
Operating Guide for the informatin to format the hard disk drive and reset the camera to factory specifications.
Operating Guide:
http://www.docs.sony.com/release/DCRSR100.pdf
