20 Most Recent
Panasonic TC-32LX60 32 in. LCD Television Questions & Answers
Red blink 2x
Good day,
I am reading that this is a circuit failure. I would refer you to a technician to repair/replace the board.
Good luck...
12/4/2017 12:48:04 AM •
Panasonic...
Answered
on Dec 04, 2017
Smps section is not working
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
8/11/2014 5:09:25 AM •
Panasonic...
Answered
on Aug 11, 2014
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
6/23/2014 1:30:32 AM •
Panasonic...
Answered
on Jun 23, 2014
No sound
can you get sound from the back RCA connectors (red and Yellow ) to a sound bar. if yes I have see a-lot of TV off the line that the connector at the bottom of the MAIN board is disconnected....
5/25/2014 7:55:43 PM •
Panasonic...
Answered
on May 25, 2014
HDMI port is failing
DON'T wiggle it anymore because the connection solder points are loose and you will eventually crack the connector or the PCB it's soldered to. If it is not to much hassle you can remove the TV/Case cover and hit the points with a soldering iron.
11/11/2013 12:22:45 AM •
Panasonic...
Answered
on Nov 11, 2013
No power but has red light flashing
Thank God for the internet. I had the same problem and I googled it and found this site with this solution. It worked fine. Thank you. Like you said, unplug, hold the power button for 60 seconds and replug and turn on. Worked like a charm. Thanks a bunch.
6/19/2013 8:40:13 PM •
Panasonic...
Answered
on Jun 19, 2013
