If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
Driver
downloads
and
Installation Instructions
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
1: Download a disk read error repair tool,install this error repair tool.2: Open disk read error repair tool and scan you computer for free3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi...
or rather than doing this try the alternative which is windows own repair
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any
bad sectors or you could tick one box and wait until its finished then return and tick the other box then select check now start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer also download a registry cleaner
http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
hope this helps
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
28 questions posted
76 Questions
22 Questions
12 Questions
4 Questions
2 Questions
