20 Most Recent Samsung HT-Q70 Home Theater System System Questions & Answers
The system plays the music but the voices are
Look on the remote for "mode", "effect" and or the "sound edit" buttons. There are a few different sound effects to choose from.Your manual:http://downloadcenter.samsung.com/content/UM/200603/20060310100609484_Q70_XAA_ENG.pdf
11/4/2013 1:16:30 AM • Samsung HT-Q70... • Answered on Nov 04, 2013
When a movie is playing, you can hear all sounds
The voices are probably coming out on one of the channels that has a bad speaker, bad wire, loose connector, or bad output. If you have the audio set to 5.1 output, change it to two-channel stereo output. The voices should return to normal.
11/3/2013 2:20:26 AM • Samsung HT-Q70... • Answered on Nov 03, 2013
0answers
Everytime I turn my on samsung ht-q70 the display
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
6/23/2010 12:28:29 PM • Samsung HT-Q70... • Answered on Jun 23, 2010
Upgrading DVD quality
Hi.
It displays 480i or 480p because that is the maximum resolution of a DVD. DVD cannot go over that limit.That is already improved to the max.
To get an higher resolution you need to use blue ray.
4/8/2010 6:27:02 PM • Samsung HT-Q70... • Answered on Apr 08, 2010
I had static electricity go from my finger to the
This is a known defect with this system. Lots of them have died this way. Find a Samsung service shop....
3/22/2010 3:44:22 PM • Samsung HT-Q70... • Answered on Mar 22, 2010
Turned on system. it shut off. tried to turn it on
If every segment on the display lit up it will need a display driver IC (pain in the a## to replace need to remove the display to get at it) and it will also need a transistor in the power supply.
2/11/2010 2:02:14 AM • Samsung HT-Q70... • Answered on Feb 11, 2010
My Samsung HT-Q70 5 disc drawer won't stay closed.
make sure its fully cleaned. many appliances will automaticly open the disktray if there is a reading error. DO NOT TOUCH THE LENS. i suggest a simple blow over the lens and cleaning the disk, try again. if all else fails, contact your seller and get a trade in.
12/30/2009 1:13:17 AM • Samsung HT-Q70... • Answered on Dec 30, 2009
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
12/19/2009 6:36:41 PM • Samsung HT-Q70... • Answered on Dec 19, 2009
I just want to know if I can connect my laptop to
Yes you can and it is very simple. All you need is a special wire. One end fits to the earphone jack on the laptop, and the other end looks like rca cable. At the back of your home theater choose aux in, and connect the rca end of the cable to that. Then the other end looks like a headphone jack, and you connect that to the laptop headphone jack. Now on you home theater select aux. You will everything that comeout of that laptop including the windows vista melody when you first boot it up. Now you are ready to enjoy music.
11/23/2009 11:59:08 PM • Samsung HT-Q70... • Answered on Nov 23, 2009
How do i connect/play my turntable?
Hi sorry to say cant go direct.
What you can do if really want it running is get a RIAA pre amp with power supply (search google local shops). The turn table plugs into that, then that plugs into one of the analogue inputs of the Q70. That will work great if prepared for the effort!
Best of luck
7/22/2009 6:52:05 PM • Samsung HT-Q70... • Answered on Jul 22, 2009
Can't get the disc drawer to open/ close
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
7/3/2009 2:20:41 AM • Samsung HT-Q70... • Answered on Jul 03, 2009
38 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
upgrading dvd quality
  • Audio Players & Recorders
