Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch
OFF and switch
ON your TV with its
FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
