20 Most Recent
Magic (ED8000) Professional Microphone Questions & Answers
Microphone not working
Possibility problems: check cord by opening the back side if your mechanically incline that's if direct cord hard wire into device (mic).
Secondly could be bad power circuit board means you have to sent it out to online address for Sing along distributor/service like Ace karaoke for $100 buck or so.
Well the ac adapter still
HiElectronic equipments dont work with ac supplies. That the fact is they need d.c. and in your case a.c. power goes through rectification and regulation in which case by feeding over voltage into your system you have probably damaged rectifier diodes and the regulator and these items are very cheap.N.B. if you are going to do the repair yourself check for burnt and melted copper tracks.
My ed 8000 mic cable
Hi, I think a local musical instrument store may provide the most inexpensive. Someplace such as Guitar World or someplace similar. I would think you shouldn't have to pay more than fifty dollars to get it fixed. Good luck, I hope I was helpful-please comment back as I need some votes to boost rank and THANK YOU for choosing FixYa, Prodzilla
Video works but no sound at all
yee..check if you connected phono cables and try turn on and off your telly. yellow-this is vision,,,red--right channel,,,white-left channef of your sound...try also in menu options
I can see the tv but it doesn't sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Entertech mic ed-9000--Mic stopped working
Could be the wiring in the RCA cable.
Swinging mike to and fro can wear through the power wiring inside the cable.
I'm on my 3rd cable.
Manufacturers have said they recognise this is a common fault with product but it seems they are not taking any steps to rectify.
I found that using the mike with batteries sometimes works.
If you get a new cable may be a good idea to reinforce the top 12 - 18 inches of the cable to avoid same problem in future.
ED-8000.
You can not because the songs are in different format. the only thing that you can do is to use recording chip, insert in magic sing, record some songs or record your singing then upload it in your PC using the download manager CD and USB cable
the unit comes with a cd download manager (window XP) and a USB cable. the you can uploaaad your recorded songs in your PC.
No sound comes out of the mic....
there's not really any way to tell whats wrong with it apart from it seems to be damaged internally.. if you have the receipt and its still under warranty i'd take it back and not mention the drop!
Jay.D Bsc Music Technology
