20 Most Recent
Nikon Coolpix 2100 Digital Camera Questions & Answers
Transferring Video
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO COMPUTERIf your photos and videos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
New SanDisk 4GB CF Card - Coolpix displays out of memory
This is because the Coolpix 2100 and 31000 models cannot handle a card
of that large a capacity. As it's only a 2MP camera anyway it doesn't
need it.
The Coolpix 2100/3100 will usually accept up to a 512MB
CF card, and 1GB Lexar CF cards up to and including the 24x WA write
accelerated (although write acceleration itself offers no benefits on
this camera). With Sandisk only a plain old and now obsolete SDFB
allows a 1GB card to be used and the regular Sandisk Ultra (not Ultra
II or later) will only work up to 512MB.
The camera was
discontinued long before these much larger CF cards were released and
Nikon no longer actively support the product so no firmware updates
will be available. The hardware wouldn't support such cards anyway.
Compatibility chart for CF cards address below:-
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/26030/c/241/r_id/127673
I wish to use 1Gb
Sorry to say but this camera can only support a maximum 512 MB of memory card so the 1GB size will not be read by this unit.
All I need is the
You can download a copy of the manual from the manufacturer's web site at
http://www.nikonusa.com/pdf/manuals/coolpix/CP2100man.pdf
Pictures wont download to computer
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as Nikon Transfer.
The lens is stuck and
Follow this steps in order the resolve the issue.
- What you can try to do is spray some compressed air into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
- Switch the camera OFF and then ON again 2-3 times.
- Remove and recharge / replace the battery, If the error does not clear, Keep battery battery out of the camera overnight, and try again the next day.
Else your device need service (repair)
Good Luck & have a nice day.
How do I erase all the pictures from a Nikon
That's not a good idea. If you have stored the pics safely on your computer, you can completely erase the card in the camera by going into the menu and finding "format"...follow the on-screen instructions.
