20 Most Recent Nikon Coolpix 7600 Digital Camera Questions & Answers
Screen/pictures are black
Sounds like your screen has died. Check with an authorized Nikon dealer.
6/2/2016 8:24:39 PM • Nikon Coolpix... • Answered on Jun 02, 2016
HOW TO MAKE DATE SHOW ON PICTURE
turn the round dial to set first option is date set date and turn it on
7/5/2014 10:06:32 PM • Nikon Coolpix... • Answered on Jul 05, 2014
Why isnt my camara reading my sd card
I have found some sd cards do not work in my camera try a different card.....
7/5/2014 10:01:09 PM • Nikon Coolpix... • Answered on Jul 05, 2014
2answers
Memory card is write protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/21/2013 6:55:34 PM • Nikon Coolpix... • Answered on Oct 21, 2013
How do you turn the flash off on a Nikon Coolpix 7600 Digital Camera
Press cursor-up to bring up the flash menu. Select the lightning bolt in a circle to turn off the flash.
5/1/2012 4:35:41 PM • Nikon Coolpix... • Answered on May 01, 2012
I need a driver for Mac. I can not get my pictures
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.
6/29/2011 8:20:51 PM • Nikon Coolpix... • Answered on Jun 29, 2011
I am plugging my cord
Use a card reader and download to a folder you create on your desktop. From there, you can import the pics to iPhoto. typrice_97.jpg
1/19/2011 1:01:39 AM • Nikon Coolpix... • Answered on Jan 19, 2011
MY NIKON COOLPIX 7600 WILL NOT TURN ON. I HAVE
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Regards 8ushy
12/24/2010 3:15:24 AM • Nikon Coolpix... • Answered on Dec 24, 2010
Error msg, this card cannot
format the card or take it to Staples and ask if they will or can tell you how. It is easy tho. I just put them in my pc and hit format.
Rice @ Fix Ya
10/23/2010 4:13:47 AM • Nikon Coolpix... • Answered on Oct 23, 2010
Just shows lense error when switched on
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
9/11/2010 4:07:12 AM • Nikon Coolpix... • Answered on Sep 11, 2010
7600 lens error
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
8/13/2010 5:08:11 PM • Nikon Coolpix... • Answered on Aug 13, 2010
Nikon Coolpixs 7600 Battery door
Choose your color at http://uscamera.com/cp7600.htm
6/14/2010 11:05:16 PM • Nikon Coolpix... • Answered on Jun 14, 2010
Camera won't turn on, although
Does the camera indicate that its on in any way? Like blinking battery light or stuff like that?
5/15/2010 12:51:54 PM • Nikon Coolpix... • Answered on May 15, 2010
Coolpix 7600 lens are out and camera is off.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/18/2010 4:43:07 AM • Nikon Coolpix... • Answered on Apr 18, 2010
What do i do
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2/22/2010 2:48:35 PM • Nikon Coolpix... • Answered on Feb 22, 2010
Nikon Coolpix 7600 Digital Camera Logo
44 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
memory card write protected
  • Cameras
