20 Most Recent
Fisher and Paykel Fisher Paykel 21768 - ActiveSmart Refrigerator W/ Right Hinge (White) Questions & Answers
I have a Fisher &
It sounds like your freezer is going into reverse cycle and therefore still running but defrosting.
Sensors or control unit could be faulty.
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
if u can hear the compressor going , then dont worry about fixing it , it would need to be regased , not worth it too old, if u cant hear the compressor going then it wud be a cheap fix wud need a new thermostat or a defrost timer
Hi, I have a Fisher and Paykel E402B
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Fisher and Paykel fridge E521T is not cold enough?
If your Fisher and Paykel E521T fridge isn't cooling properly, check the temperature settings, clean the condenser coils, ensure proper ventilation around the fridge, and inspect the door seals for any leaks. If issues persist, consider contacting Fisher and Paykel customer support or a professional technician for assistance.
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
