20 Most Recent Avanti EWC28 Wine Cooler Questions & Answers
0answers
Fan
Be the first to answer 4/6/2014 3:10:15 AM • Avanti EWC28... • Posted on Apr 06, 2014Be the first to answer
0answers
Wc 600
Be the first to answer 3/30/2013 7:15:20 PM • Avanti EWC28... • Posted on Mar 30, 2013Be the first to answer
0answers
Wine cooler has no light or power working it
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
1/3/2011 7:51:12 PM • Avanti EWC28... • Answered on Jan 03, 2011
Moved cooler and wont restart
try leaving unplugged for a couple hours then plug back in
5/19/2010 11:31:25 AM • Avanti EWC28... • Answered on May 19, 2010
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
4/26/2009 11:25:46 PM • Avanti EWC28... • Answered on Apr 26, 2009
0answers
0answers
0answers
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
1/3/2008 7:30:16 PM • Avanti EWC28... • Answered on Jan 03, 2008
AVANTI WC40D
it is replace able but if you get the new door is better for you.
12/29/2007 6:30:22 AM • Avanti EWC28... • Answered on Dec 29, 2007
0answers
0answers
Error EE
Be the first to answer 12/26/2013 3:32:48 AM • Avanti Furniture • Posted on Dec 26, 2013Be the first to answer
Home Meridian Comfort Lift Recliner Chair model 175-60-126. All functions work including recline, but lift does not work?
Question edited for clarity, make model (what it is)'. Duplicate question deleted, refresh page to see your question. You would have to check the controller wires and buttons with a multimeter. Then test down to the motor. Then test the motor itself. Some parts are available. There is a history of issues. .. https://www.google.com/search?q=Home+Meridian+lift+chair+175-60-126+lift+not+working ..
4/25/2024 11:34:36 PM • Furniture • Answered 5 hours ago
How can I ensure the quality of a sofa when ordering online in the UK?
Your budget determines how much quality the sofa has
4/18/2024 10:12:05 AM • Furniture • Answered on Apr 18, 2024
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
  1. Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
  2. Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
  3. Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
  4. Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM • Furniture • Answered on Apr 17, 2024
Colorado metal 4 seater dining set with parasol assembly instructions please?
Question edited to remove Funky-Dash-Use- :>D Lots of pretty pictures, but no instructions. If it is new, reach out to the store or the online seller. It looks pretty easy by looking at the pictures and zooming in on the B&Q website. Lay all the parts out. https://www.google.com/search?q=Colorado+metal+4+seater+dining+set+with+parasol+assembly+instructions ..
4/14/2024 5:11:05 PM • Furniture • Answered on Apr 14, 2024
Avanti EWC28 Wine Cooler Logo
18 questions posted
Top Avanti Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
View Most Popular
Avanti Furniture
  • Avanti Furniture
Most Popular Question
avanti ewc28 wine cooler cool
  • Furniture
