20 Most Recent E-Machines AAFQ50400000K0 Keyboard Questions & Answers
2answers
My e164844 keyboard the feet are broken can they
We, Global Interscope are one of the leading swimming pool designers, renovators, and contractors, for both commercial and residential. Over the years, the company with its expertise has created spectacular Swimming pools for both indoor and outdoor areas. We also working as channel partners for Drainvac (Central Vacuum Systems ) Retractable enclosures of Megavent Water Softeners and Purifiers from 3M and Invisible Grills from Lehomes Singapore. doc1_1-1-ocphgtp455dkjtp4vdcpuodl-2-0.jpg https://globalinterscope.com/
3/17/2019 2:13:42 PM • E-Machines... • Answered on Mar 17, 2019
2answers
My keyboard has stopped working unexpectedly.
try uninstalling the key board driver and downloading the driver from the manufacturer web site win xp and win 7 is no longer supported so win drivers are becoming a problem
12/13/2017 6:53:29 AM • E-Machines... • Answered on Dec 13, 2017
I can not get my keyboard to work
Try plugging it in to a different PC to see if its the keyboard or your PC.
10/2/2012 9:18:32 PM • E-Machines... • Answered on Oct 02, 2012
0answers
The keyboard just stopped working.
Update your keyboard drivers. You only needy our mouse for that. Go to E-Machines homepage and search for your model number, then look for keyboard drivers. Good luck to you! Please leave me a good rating, thanks! :)
7/27/2011 6:53:04 PM • E-Machines... • Answered on Jul 27, 2011
2answers
Keyboard types very slowly and
Sounds like you have too many things running possibly that's slowing the system down. You can try downloading malware bytes from www.malwarebytes.org and running a scan to remove any malware you might have. If that doesn't work, try that keyboard on another system to see if the problem is with your keyboard or with your computer.
6/27/2011 5:17:20 AM • E-Machines... • Answered on Jun 27, 2011
Where to transfom keyboard to
Click on Start - Control panel - Location settings.
4/6/2011 2:27:26 PM • E-Machines... • Answered on Apr 06, 2011
My keyboard will not type
It looks as though you have an incorrect language set selected. At the foot of the screen you will see "EN" for English for example - - just double click on the icon for whatever one you see and from them you can open the language tool bar and change the settings to suit.
3/21/2011 6:50:40 PM • E-Machines... • Answered on Mar 21, 2011
Can't find anything on my
Hold Control (Ctrl) and press P
3/9/2011 5:29:17 PM • E-Machines... • Answered on Mar 09, 2011
0answers
The double quotation mark is not working
Learn or familiarise with the kyboard to achieve results. Acquire a replacement keboard instead.
2/9/2011 7:42:41 PM • E-Machines... • Answered on Feb 09, 2011
Trying to help a friend figure out how to use the
try holding the shift key and press @ key
1/29/2011 3:34:11 PM • E-Machines... • Answered on Jan 29, 2011
How do i get the question mark.
shift + / those two when done together, should give you the ? that you are seeking. Being an e-machine, they probably didn't print the ? symbol on the key to save a coupla bucks.
1/24/2011 1:13:30 AM • E-Machines... • Answered on Jan 24, 2011
Several keys on my keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines. dust causes static which causes lots of problems with a computer and its parts or if this does not fix the problem click start control panel keyboard you can change your settings there or you might have uninstall the keyboard restart your computer then reinstall it and its drivers click start control panel keyboard hardware then properties you should see driver details,update driver,roll back driver,uninstall make sure you have the driver for the keyboard before uninstalling the driver make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver you could run the check disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart hope this helps
1/21/2011 12:27:09 AM • E-Machines... • Answered on Jan 21, 2011
What does the moon key do? I pressed the moon key
Yes, the laptop is in a sleep mode but the Windows operating system is running in the background. Push the power button to turn the display back on.
1/20/2011 7:08:18 PM • E-Machines... • Answered on Jan 20, 2011
I bought a replacement keyboard
Sorry to read about your problem, I hope this helps you out.
you should not need any drivers, for basic operation. and since you tried 2, i think you have a defective mother board, you can maybe try a usb keyboard, you will need to load drivers.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
1/6/2011 3:17:40 AM • E-Machines... • Answered on Jan 06, 2011
My little baby cousin was
Try reboot unit. if that doesnt work hit CTRL-F7
1/2/2011 7:12:45 PM • E-Machines... • Answered on Jan 02, 2011
Wil not tye whole words
Did you spill any liquid on this? I'm asking because this is symptomatic of a shorted keyboard controller. It could also point to a ribbon cable that has come detached from the motherboard, or has chafed and one of the traces has been damaged.
Keyboard will need replacing if this is the case
1/1/2011 7:30:51 PM • E-Machines... • Answered on Jan 01, 2011
Keyboard making clicking noise but not typing
keyboard not working but hear clicking noise
12/28/2010 8:32:36 PM • E-Machines... • Answered on Dec 28, 2010
Computers & Internet Logo
82 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
wil not tye whole words
  • Computers & Internet
