20 Most Recent
Hyundai HPT-4250 Television Questions & Answers
Trere are lines running up
Try to adjust the vertical hold trimer.In adjusting the trimer you look the screen while adjusting the trimer until the screen or picture back to normal.
I have a hyundai hpt
what would cause a 1inch black line too appear on my tv screen..and how do i fix it.thanks
There is a thick black line down the middle of the
hi all .ive had the same problem,a thick black line down
screen.sometimes it flickers from top to bottom and other permantly in
view.but i have solved it.forget your ic boards and taking apart tv.have
you got either a ps3 or wii connected to tv.if so unplug power lead
from socket and relocate in seperate socket.make sure the lead is
completely free of any other leads and you might just find this works.i
think the power lead creates some sort of frequency that the tv picks up
.good luck hope it works
When tv turned on screen
Several causes can be attributed to this. If the contrast and brightness have been tampered with then the display remains black.
On the other hand if the picture IC is fried then this is possible. In this case you have to refer your unit to an expert.
Hope this solution has been helpful?
Sky HD being installed, but
May I know what exactly the model that you have? As common audio input it can be a RCA conections, and you need a RCA cable for that
