20 Most Recent
Sansui COM3101 13" TV/VCR Questions & Answers
Have a rca remote and a spongebob tv and cant get it to program
027,018,038,093,033 are the codes to check.
If you wish to get more details, check this
site. Pull up older posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your
problem. Search the site by 'Timeslide'
option. It will make search easy. Or, type in the brand name to your device
into its search box, and press "Enter."
Using an RCA universal remote
WIKIPEDIA has this link for your situation:
How to Program an RCA Universal Remote Without a "Code Search" Button
http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button
I think that should help with your situation. Let me know if it does not.
I have no remote and
With the set switched on pull it's AC plug out of the socket then switch the manual button on the set to Off.
Leave for 10 minutes, plug back in, switch on and see how it is.
Screen becomes small in breadth
I am assuming that "breadth" means the vertical height. It is a common problem, associated with 2 components. Either the Vertical Output IC and/or the vertical yoke coupling capacitor. Either of these can cause a similar problem. If you are handy and have the proper equipment, you can do it yourself. Locate a schematic, locate the Vertical output IC, order the replacement IC from a parts distributor like MCM Electronics or equivalent and replace it.
If you are not handy, this should be under $100.00 for a professional repair at any TV repair shop.
TV does not respond to remote. Remote tests OK and
Hello
Your TVs infrared sensor is not taking the infrared pulse from your remote control. It may be faulty. It is fitted on the ciruitboard just behind the infrared sensor window. It is three pin component, and can be resoldered out from the circuit board. There are differnt numbers of infrared sensors, used in Sanyo televisons. You just open the tev, draw the circuit board out of it, and you can see black tree leged element soldered to the circuit board. Just resolder it out from the board, and go for a same type and number. Replacing it will solve your problem. Before desoldering it out, check its present soldering for any fault. Check the voltage at the pin number 1 of that sensor. It should be around 5VDC. If it is there not check for any resistance for break.
If all other functions are working with its front control panel, the 5vDC voltage mentioned above will be there, since system control IC needs this voltage, and from which the supply to the infrared sensor also is given. It is a most common fault in all TVs. OK.
I need a remote for my 13 inch television with a
Hello, this should be the correct model number of the remote: 07660CG020
Here is an ebay auction for one:
http://cgi.ebay.com/07660CG020-REMOTE-CONTROL-for-TV-VCR-Combo_W0QQitemZ120378205047QQcmdZViewItemQQptZLH_DefaultDomain_0
On screen message "DEW"
DEW on the screen means that there is moisture in set. Leave the unit on for several in a warm dry place. The heat from the picture tube will help dry out the set.
