20 Most Recent
Royal VF1012mx Shredder Questions & Answers
Every time we insert paper,
Have you ever oiled the cutting shafts....all cross-cut shredders require some amount of lubrication....the more you use it the more it should be lubricated. You can get a bottle of lightweight shredder oil from the same place you got the machine.
My VF 1012mx paper shredder
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
A piece of junk mail
Unplug the machine.
Remove the waste bin.
Remove 4 screws inside underneath to take cutting head off the basket/cabinet.
Turn the cutting head over and remove 6 screws that hold the top cover onto the bottom. Turn the unit back over and remove the top cover...remove the medallion if jammed...check the gear train to see if it has broken any teeth in the drive gears.
If you need parts contact Royal at 1-800-524-0799.
How do I unclog my shredder?
The papers keep
Have you ever "oiled" the cutting blades...all cross-cut shredders should be oiled regularly otherwise they clog up with the paper and debris generated by the cutting of the paper...the oil helps feed this material on thro into the shredding bin.
MY SHREDDER WORKS BUT WILL
Try cleaning the eyes first...if that dosnt work and you feel they have to be replaced you can contact Royal at 1-800-524-0799 for parts assistance.
MY ROYAL CROSS CUT SHREDDER
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
