20 Most Recent Tivo DirectTV Remote Remote Control Questions & Answers
0answers
2answers
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
11/8/2013 6:36:35 PM • Tivo DirectTV... • Answered on Nov 08, 2013
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.God bless you
11/8/2013 12:03:13 PM • Tivo DirectTV... • Answered on Nov 08, 2013
Will not record 2 channels at same time
use the troubleshooting Direct TV, from your TV section and follow the steps.go http://www.directv.com/DTVAPP/content/support/troubleshootingGod bless you
7/28/2013 3:52:19 AM • Tivo DirectTV... • Answered on Jul 28, 2013
Anbonn lcd tv code
Check these codes. 1061 1091 1052 1423, 1027 1031. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option.
7/19/2013 10:01:49 AM • Tivo DirectTV... • Answered on Jul 19, 2013
How to set up bauhn universal remote
how to set up bauhn universal remote control for tv vivo lcd
4/23/2013 12:12:00 PM • Tivo DirectTV... • Answered on Apr 23, 2013
What are the volume codes for a directv remote and a Soyo tv
go to www.fitness.manualsonline.com or www.remotecodelist.comfor free downloadGod bless you
7/18/2012 11:37:03 AM • Tivo DirectTV... • Answered on Jul 18, 2012
My direct tv remote control
Hi Mr: sherrer,
Did you try to change the battery, and see if it would work again as it was before?
Do this please, and let me know if the problem is solved.
Best Regards.
6/14/2011 2:11:20 AM • Tivo DirectTV... • Answered on Jun 14, 2011
tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
I hooked up a SamsungDVR
I can help you with your DirectTV RC65 and Samsung SIR-S4040R PVR.
First of all, if you would like a digital copy of the TIVO RC65 remote control manual for your reference, it is available here.
Now, it sounds like you have partial control of your Samsung DVR with the remote, but not complete control. Here is the 5-digit control code for your Samsung SIR-S4040R : 01442.
To program your remote with this code follow these steps:
  1. Locate the 5-digit code for your DIRECTV® Receiver. In your case, the code is 01442. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turnoff; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
The 01442 code is specific to your Samsung S4040R. However, if you find that you are stil unable to power off your DVR, you may wish to try these other Samsung DVR codes to see if for some reason one is more compatible: 20739, 00001, 01142, 01276, 01108, 01109, 01442, 01609, & 01708.
I hope that helps.
4/2/2010 9:52:27 PM • Tivo DirectTV... • Answered on Apr 02, 2010
tip
DirectTV RC65 Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
Remote to my tivo won't work my on/off and volume on Akai TV
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
2/18/2010 3:55:06 AM • Tivo DirectTV... • Answered on Feb 18, 2010
I need to program my tivo remot to use with a
you can key in your units and get the most likely codes at
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380036#h:620.480
11/3/2009 1:34:51 AM • Tivo DirectTV... • Answered on Nov 03, 2009
Tivo DirectTV Remote Remote Control Logo
Popular Tags
48 questions posted
Top Tivo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tivo Televison & Video
Most Popular Question
tivo directv remote program akai
  • Televison & Video
